Results 1 to 14 of 14
Thread: Valves require adjustments ?
    Sep 2016
    England
    Hi Guys
    just wondering if any of you have actually had to adjust clearances ?
    My 2013 Capo12 is due it's annual service in Jan, now done 17k and not had valves
    checked yet.
    Of course I'm debating whether to pay big money to have them checked
    only to find they don't need doing.
    Sep 2013
    Shropshire UK
    Quote Originally Posted by Italiatwin View Post
    Hi Guys
    checked yet.
    Yes, 2013 bike, two valves adjusted at 12K miles.
    apriliaforum Member coolonthecoast's Avatar
    Jul 2017
    Yorkshire Coast
    Quote Originally Posted by RSTman View Post
    Were the two valves you needed to adjust far out of spec?
    1200 Capo Travel Pack and a '85 Honda VF1000RF.
    Sep 2013
    Shropshire UK
    Quote Originally Posted by coolonthecoast View Post
    Yes. A significant amount. I can't remember how much now. Both exhaust valves on the front cylinder. One too loose the other too tight. I suspect they had been like it from new TBH. Believe me, I checked and re-checked to be sure before contemplating adjustment! The inlets on the rear cylinder were border line tight, decided to leave them. Will look again at 24k miles, if I still have the bike by then. If they are the same they will be left alone. I get the impression these engines were not assembled with the same care as the V990 Rotax motors.
    I would say the first 12k mile check from new is essential.
    Checking the clearances is time consuming (you have to remove the rad to get to the front cyl). But remember you need to change the plugs, and the coolant, and the air filter as part of the service (the rad has to come off for the front plugs too). If the valves are in, or very close to spec then you can assemble it all with new plugs, coolant and filter and save your self a bundle. But if valve need adjustment you have to decide if you're up for it, or you have assemble everything, go to the dealer and then pay them to do all the disassembly/assembly again. I went for it and did it at home. You can get Hotcams shims online, they are the same size as some Jap bikes. The aprilia ones are more expensive plus Fowlers didn't have stock of the sizes I needed anyway.
    As for service history at resale, I photographed the engine with the cam out and keep all parts receipts. TBH I'm not bothered really, the residuals are so poor anyway, need to save on service costs to try and preserve what is left of the capitol in the bike!
    If you are in the Midlands and you need to have the work done, give Aprilia Performance a try in Tamworth. They are very good non franchise Aprilia specialists.
    Apr 2014
    Hertford, UK
    Griff is the man...........
    Jul 2016
    Montréal, Canada
    I am up for the big 20k service as well.
    My thought was to strip the bike at home in my garage all the way down to valve covers and load it on a trailer to bring it to the dealer for him to open valve cover and do adjustment if needed. I will do the rest myself (filter, plugs, coolant).
    This way I save a lot on labor cost and leave the stuff I am not comfortable with to the dealer.
    I also have help from the fact that we have 3 feet of snow outside and have the luxury of time to do that during our long winter in Canada.
    2015 Caponord White TP
    Heated grips, Gel seat, Givi Screen, Aprilia Top Box, GPR Exhaust, ESE Healtech, DNA Stage 2 Filter, RapidBike Easy Module, RAM Phone mount
    apriliaforum Member Falcoholic's Avatar
    Mar 2007
    Scotland
    Quote Originally Posted by chrisu View Post
    I have just sent him an email enquiry of approximate cost and amount of time required for the full 12000 mile service
    Will see what he comes back with and whether it will be worth making the trip in the spring.
    The Delicate Sound of Thunder
    apriliaforum expert Frodo's Avatar
    Jul 2007
    Kapiti, New Zealand
    I presume that checking / adjusting valves is the same on the Capo as on the Shiver/DD 750, but our radiator needs to be shifted rather than removed. IMHO ckecking valves is a must and not difficult to do. You can then decide to adjust them, as RSTMan noted. There is a detailed illustrated how-to thread in the Shiver/DD forum. The cams are driven by gears from the cam chain so easier to remove to change shims than many bikes. Key tip is to zip tie in the non-removed cam in the front cylinder so you don't lose cam timing. As with RSTMan, I bought a set of Hotcam shims.
    Frodo
    2015 Shiver
    New Zealand
    Sep 2013
    Shropshire UK
    Griff is indeed the man. Great guy and knows Aprilia's inside out.
    See and listen to Griff talking about the Tuono V41100 here.
    https://www.youtube.com/watch?v=ABfxGC_XjpA
    Sep 2017
    UK
    I phoned Griff on Friday about doing the valve clearance check and adjustment on mine. He said he's never worked on a Capo 1200, so declined working on it. He asked whereabouts I was in the country, I told him North Yorks, so he recommended taking my bike to Teasdales to get it done
    Sent from my iPhone using Tapatalk
    Sep 2013
    Shropshire UK
    Quote Originally Posted by AndyRoo View Post
    That's a shame. Thanks for the info.
    apriliaforum Junkie Rockbyter's Avatar
    Aug 2015
    Co. Durham, England.
    Teasdales always been OK for me, that's where the Caponord I had and coolonthecoast now has came from. Bought the KTM there too, get a loaner and take a ride over to Whitby.
    Sep 2013
    Shropshire UK
    Quote Originally Posted by Rockbyter View Post
    Teasdales seem to be one of the better dealers for Aprilia service in the UK. Based on past experience no way was my supplying dealer going anywhere near the valves on my bike.
    Aug 2015
    I know people say stick to an Orange dealer for KTM but we just don't have the option so I stick to the people that treat me right. Teasdales is very much a Family business with Andy running the show with his wife, daughter and son plus others.. Dan his son is in the workshop and always seems approachable and does a good job.
  1. UK owners...valve shim adjustment
    By styx in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-11-2005, 08:08 PM
  2. Power valve pulley adjuster,HELP.
    By AlexR in forum RS250
    Last Post: 03-22-2005, 11:34 AM
  3. Valve check/ adjustment
    By skidlid in forum ETV1000 CapoNord (2001-2007)
    Last Post: 12-21-2004, 02:10 PM
  4. Valves need adjusting?
    By Hatchman in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-17-2003, 01:27 AM
  5. Power Valve cable adjuster settings
    By tsmithy in forum RS250
    Last Post: 07-24-2003, 07:01 AM
