Results 1 to 4 of 4
Thread: 2002 MV Agusta 750S cutting out
    Mar 2016
    New Zealand
    Ok gentlemen, I have seen great advice being given and received great advice here for my Aprilia, so, I'll try for my wifes MV.
    It developed an issue, you'd be riding along, at about 6000rpm it'd cut out. Rev counter needle just dies, back to zero. The temp guage and speedo keep working. After it drops around 1000rpm or so, it'll cut back in, maybe it'll rev higher, then do it again, maybe it'll do it again at 6000. Sometimes it's 10,000, sometimes 9000, sometimes 12,000.
    I have bypassed the side stand switch, no change, on this run, it blew the 15A fuse to the coils/fuel injection system/fuel pump. I found an injector with a damaged conection, so I've ordered a new one. I found it when I removed the Power Commander, I haven't been able to test ride it since removing the Power Commander due to the injector, the terminals were broken off the injector body. I tested the CKPS in another bike, it is ok. I have given the loom the "shake" test, you know, grab it section by section and shake it, see if there are any loose connections, I did this while holding the bike at 600rpm, no issues. Fuel lines installed correctly, no kinks. Fuel tank breathers are clear. New fresh fuel. Pump primes, all fuel lines in the tank look good, pump pick up filter looks clean. I think the fact the rev counter is dropping like a stone makes it electrical. I hate electrical faults!!
    I am getting frustrated fellas, any ideas?
    Cheers,
    Shane
    My current ride: 2004 RSV1000R Factory, DNA air filter, Arrow pipes, tail tidy, Aprilia alloy muffler brackets, Aprilia Performance open airbox conversion, Carbon fibre dual velocity stacks, Bazzaz Zfi & Afm, EVO1 adjustable/foldable levers. My wife's: 2002 MV Agusta F4 750S Diamante.
    Previous:
    2006 GSX-R1000 Full yoshimura exhaust, Galfer discs and lines, Pazzo levers, Factory Pro intakes, BMC filter, Yoshimura case savers, Vortex rearsets, Toby adjustable steering damper, Yoshimura bar end sliders.
    2004 GSX-R1000,1999 GSX-R750 SRAD full Arrow race system,1998 TL1000R Two Brothers pipes, 1993 ZXR 750,1998 TZ250U,1990 TZR250,1990 KR1S 250,1986 XR250 340 big bore kit,1991 KX250, 1993 KX125,1991 YZ250, TS250X RH,1974 CR250M Elsinore
    apriliaforum expert theknurl's Avatar
    Mar 2007
    Palos Verdes Est. SoCal
    Thumbs up ?
    Shane;
    It's the safety interlock system or a bad connection......
    Check the cleanliness of all connectors, add dielectric grease and retighten
    Noel-theknurl
    The Forum Curmudgeon
    I'm not PC either
    email/PayPal theknurl@yahoo.com
    Skype theknurl
    ph. 310-414-7247 PST, GMT -8
    Feb 2005
    MO, US
    One 15A fuse handles the coils and the fuel pump? That complicates things a bit.
    It may very well have been the faulty injector, but only testing it will make sure.
    Don't be surprised if it ends up being a short in the loom, even in the wire bundle that is wrapped. Wierd stuff happens after 15 years to wire insulation.
    Mar 2016
    New Zealand
    Thank you gentlemen, I'll have another looksee, and go through all the connectors.
    Shane
    Previous:
  1. Atlantic 500 2002 Cutting Out, restarting then cutting out again.
    By sadvampire in forum Aprilia and Piaggio 500cc
    Last Post: 12-18-2013, 07:33 PM
  2. 2002 ECU + 2005 engine sporadically cutting out
    By zilog in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-26-2012, 03:44 PM
  3. Scratchbuilt: MV Agusta 750 S
    By aimhigh in forum General Motorcycle Talk
    Last Post: 10-24-2011, 02:40 PM
  4. 2002 MV Agusta F4s...Boston, $9500
    By RoyB in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 04-27-2009, 01:53 PM
  5. engine cutting out over bumps etc
    By bumblepoo in forum SL1000 Falco Forum (all years)
    Last Post: 06-30-2003, 06:12 PM
