Results 1 to 7 of 7
Thread: Aprilia antifreeze pink?
    Dec 2015
    DePere, WI
    Just picked up a used 2016 with 600 miles on it and want to make sure the antifreeze is good from the factory since i live in this F'ing hell hole of WI! Anyone know if it's pink? Thats whats in it and need to confirm before it freezes solid
    Jan 2007
    Hammond, Indiana - USA
    Yes, it's pink from the factory. You can order liters from AF1, nobody else will have the same brand and type.
    Hoosier, not hoser.
    2000.5 Mille R - Ti Shotguns & lots of Evo shtuff
    2016 Tuono 1100 Factory
    Dec 2015
    DePere, WI
    Thanks Diablo.
    Dec 2015
    Cape Cod, MA
    I used the ENI pink coolant purchased from AF1. I recall reading somewhere that you can use Toyota pink coolant as it’s similar, especially if your in a jam.
    Instagram: 0p3ragh0st
    Jan 2007
    The AGIP/ENI coolant uses OAT technology, so if you can't find the same brand/type, use something that also uses the OAT corrosion package. A lot of Japanese automakers also specify the OAT technology. It's designed to last at least 5 years.
    Hoosier, not hoser.
    Westminster, CA - USA
    Quote Originally Posted by Viper1 View Post
    If it is only 600 miles and one year old, don't replace it, test it with one of these:
    https://www.autozone.com/heating-and...ter/525881_0_0
    If you don't don't know for sure if the pink stuff is anti freeze or water wetter, get a cheap tester and be sure.
    No need to waste perfectly good coolant.
    Certified Aprilia Moto Service in Southern California
    Call me at 714 892-4056 for appointment
    Dec 2015
    DePere, WI
    I talked with the original owner and he said it was straight from the dealer.....so we should be good. Thanks for all the feed back guys!
  1. Replies: 3
    Last Post: 10-19-2012, 07:14 PM
  2. New Aprilia:What engine do you wan't?
    By Kobie in forum Professional Racing Discussion
    Last Post: 07-16-2003, 11:27 AM
  3. Not Aprilia, But whats the latest on KATO
    By Mille Ryan in forum Professional Racing Discussion
    Last Post: 04-23-2003, 10:09 PM
  4. Aprilia MotoGP Launch
    By cstarrett in forum Professional Racing Discussion
    Last Post: 03-30-2003, 09:44 PM
  5. Watch out for Aprilia at Suzuka !
    By loj68 in forum Professional Racing Discussion
    Last Post: 03-18-2003, 10:19 PM
