Results 1 to 7 of 7
Thread: Aprilia antifreeze pink?
    Dec 2015
    DePere, WI
    Just picked up a used 2016 with 600 miles on it and want to make sure the antifreeze is good from the factory since i live in this F'ing hell hole of WI! Anyone know if it's pink? Thats whats in it and need to confirm before it freezes solid
    Jan 2007
    Hammond, Indiana - USA
    Yes, it's pink from the factory. You can order liters from AF1, nobody else will have the same brand and type.
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
    Dec 2015
    DePere, WI
    Thanks Diablo.
    Dec 2015
    Cape Cod, MA
    I used the ENI pink coolant purchased from AF1. I recall reading somewhere that you can use Toyota pink coolant as it’s similar, especially if your in a jam.
    Instagram: 0p3ragh0st
    Jan 2007
    The AGIP/ENI coolant uses OAT technology, so if you can't find the same brand/type, use something that also uses the OAT corrosion package. A lot of Japanese automakers also specify the OAT technology. It's designed to last at least 5 years.
    Hoosier, not hoser.
    Westminster, CA - USA
    Quote Originally Posted by Viper1 View Post
    If it is only 600 miles and one year old, don't replace it, test it with one of these:
    https://www.autozone.com/heating-and...ter/525881_0_0
    If you don't don't know for sure if the pink stuff is anti freeze or water wetter, get a cheap tester and be sure.
    No need to waste perfectly good coolant.
    Dec 2015
    DePere, WI
    I talked with the original owner and he said it was straight from the dealer.....so we should be good. Thanks for all the feed back guys!
  1. Replies: 3
    Last Post: 10-19-2012, 06:14 PM
  2. New Aprilia:What engine do you wan't?
    By Kobie in forum Professional Racing Discussion
    Last Post: 07-16-2003, 10:27 AM
  3. Not Aprilia, But whats the latest on KATO
    By Mille Ryan in forum Professional Racing Discussion
    Last Post: 04-23-2003, 09:09 PM
  4. Aprilia MotoGP Launch
    By cstarrett in forum Professional Racing Discussion
    Last Post: 03-30-2003, 09:44 PM
  5. Watch out for Aprilia at Suzuka !
    By loj68 in forum Professional Racing Discussion
    Last Post: 03-18-2003, 10:19 PM
