Page 1 of 4 123 ... LastLast
Results 1 to 15 of 54
Thread: heated grip opinions
    Jul 2008
    Mare Island, Ca. USA
    hey all,
    i'm finally considering heated grips for the capo and probably the mana. the mana has exactly zero oem option so i'll probably go with r&g for $59 US. so here's the real question...do i want to do the same for the capo or go oem for $225 US? i'm a pretty cheap sob at heart.
    Dadsafrantic
    2015 Red Caponord #64
    Sep 2017
    Far Eastern Pacific
    I had the factory heated grips installed prior to delivery in August, and did not pay close attention to whether the control button was already present before the installation! I think so, but...in any case, the Aprilia kit works flawlessly. Whether or not another product would create CANBUS interfacing issues, someone else can answer that.
    My experience with these grips is they need a few minutes to push heat into the gloves, 3-5 minutes depending on the setting and ambient temps. I typically wear Kushitani racing gloves with a thinner kangaroo skin palm, so expect thicker gloves to take longer. This setup keeps my hands warm down into the mid-30s Fahrenheit range at highway speed, not too bad at all! I much prefer using these thinner gloves to thicker insulated models for the sake of dexterity and control feel, these heated grips facilitate that.
    apriliaforum Member heinz57's Avatar
    Oct 2016
    surrey, UK
    Go for the Oxford hot grips and have them wired into the Aprilia's switchgear. Much cheaper and does the job great.
    apriliaforum Junkie SudEst's Avatar
    Oct 2016
    Melbourne, Australia
    The OEM grips only work over a certain engine speed (2500rpm?) and donít get very hot.
    However the grip rubber is nice and...err...grippy
    Sep 2017
    Far Eastern Pacific
    SudEst, mine get plenty toasty! Fifty miles at freeway speed, December nighttime below 40*F, roadracing gloves. Not a problem! Admittedly, not quite winter in the Arctic Circle conditions. I cannot simulate Ice Station Zebra here.
    Low-speed cutoff <2500 rpm is very likely a function of the grip controller + ECU input. I'd suspect this cutoff would still occur with any aftermarket grip wired into the Aprilia controller.
    Jul 2017
    Yorkshire Coast
    Quote Originally Posted by heinz57 View Post
    I've got a set now ready to fit, its on my 2018 'to do' list.
    40 odd powered two wheelers over 40 odd years. Currently in the garage are a 1200 Capo Travel Pack and a '85 Honda VF1000RF
    Jun 2016
    Seattle, Washington USA
    Do the factory heated grips require drilling of handlebars?
    Sep 2017
    Far Eastern Pacific
    Quote Originally Posted by winind View Post
    Looking at the parts diagrams for the standard Capo and Rally versions, the handlebar shown already has pre-drilled holes on the left bar. If anyone has different info, please post!
    Here are the installation instructions:
    http://www.af1racing.com/store/prodimages/st3/2s000044_d7.pdf
    Nov 2015
    DFW Texas
    My 16 Rally was predrilled.
    Regards,
    Darrell
    apriliaforum prov-nov Funtik's Avatar
    Apr 2016
    Russia, Moscow
    Instructions for my 2015 kit...
    Aprilia RST Futura 2003, Ash Gray.
    Aprilia Caponord 1200 Travel pack 2014, Red
    Sep 2017
    Far Eastern Pacific
    Thank you Funtik! Looking at the instructions I could not find any mention of having to drill holes during installation, so they are very likely pre-drilled from the factory.
    Forsyth Ga.
    That's correct, I watched the dealer install mine in about 15 minutes. Bars were already setup for them, no drilling! I would have done myself if not for the fact they did it free when my sending unit was being replaced. I did buy the grips from them.
    Jul 2008
    good to know thanks.
    Dadsafrantic
    apriliaforum Junkie WyoRidr's Avatar
    Sep 2005
    Cody,Wyoming
    So,do the factory heated grips not work till 2500 rpms?I have yet to see mine come on on my 2017 Capo.Cruise works but no grips yet?
    Sep 2017
    Far Eastern Pacific
    Optional Equipment
    Wyo, yes, there is a low-rpm heater cutoff. 2500 sounds about right.
    My salesman told me the bike came with heated grips as standard, luckily someone knew otherwise or else my hands would always be cold!
  1. Heated Grips?
    By Bonnieville in forum SL1000 Falco Forum (all years)
    Last Post: 09-15-2003, 08:05 AM
  2. Heated Grips
    By pnoud in forum RST1000 Futura (all years)
    Last Post: 05-15-2003, 10:48 AM
  3. Heated Grips & Scottoiler & North West 200 Races
    By ALLAN in forum RST1000 Futura (all years)
    Last Post: 04-09-2003, 03:12 PM
  4. Heated Grips Advice
    By Jack in forum ETV1000 CapoNord (2001-2007)
    Last Post: 10-30-2002, 10:06 AM
  5. Heated Grips
    By CharleeTho in forum Pegaso 650 Cube and IE
    Last Post: 10-26-2001, 03:38 PM
