Results 1 to 7 of 7
Thread: Shift Peg / Brake Pedal (Installing Rubber Pad AKA Toe Lever Rubber)
    Yellow Shirt
    Jul 2012
    Pacific NorthWet
    Hello All!
    I searched the forums and didn't find any useful information that would answer this question so I am posting it here.
    I am replacing the rubber pad on my brake pedal (Pictures below)
    Brake / Clutch Pedal Part Number: 8121221
    Brake / Clutch Pedal Rubber Pad Part Number: 8120912
    My question is.
    I am having a VERY hard time getting the rubber pad to fit over the peg.
    Can anyone who has done this before lend a tip or a trick? Any and all help would be greatly appreciated.
    Aug 2015
    Gilbert, Arizona (USA)
    Put the peg in the freezer, and the rubber in a pot of boiling water, then try. Sounds funny, but it works.
    Jan 2015
    Surrey, UK
    no need for freezer, just drop rubber in hot water for a few seconds.
    Dorsoduro 750 - commuterised
    Hayabusa Gen2 - never gets wet
    SV1000SZ - heavily modified
    GSXR750K 1989 Slingshot - owned from new
    GSX750 Inazuma - old commuter
    SV650 Curvy - top all rounder
    apriliaforum Junkie maxredline's Avatar
    Sep 2016
    BC Canada
    Soap!
    I put on some clear tygon tubing so that it does not stain my other than motorcycle boot/shoe.
    I'd rather be on my bike thinking about god than be in church thinking about my bike 8)
    apriliaforum expert brandonmccann's Avatar
    Jan 2013
    Edinburg, Tx(Rio Grande Valley)
    This thing is the worst to install. I think I actually used a vice to hold the rubber, and then shoved the piece onto it.
    If I didn't have my aftermarket rearsets I would just order toepegs without the rubber it's such a hassle.
    Though, hot water may have made it easier as andyL suggested.
    *WTB* - Healtech quickshifter, GLpro X gear indicator, aftermarket shock, adjustable fork cartridges, HLD Large Rear Fender, Carbon tank panels; For 2009 Shiver.
    **For SALE** - MotoCorsaro O2 Optimiser, OEM Brake and Clutch Master Cylinders W/ Mad Hornet adjustable levers,OEM mirrors and stock muffler; From a 2009 Shiver.
    2009 Aprilia Shiver; Rexxer ECU Reflash, Apex Clipons, 520 45T, DNA filter and snorkel removal, Accosatto clutch & brake masters, Mussan MPdemon header & decat link pipe, Skidmarx Bellypan, HLD seat cowl, Sport Screen, CRG Arrows, LED retrofit(Opt7, Zevo, Watsen), R&G Tidy, Rosmoto Rearsets, T-Rex Sliders.
    Nov 2016
    Lincoln
    This was a real bugger. Hot water helped, but it cools quickly on the lever, so I kept some water handy. I was confident because I'd done a kick start rubber the same way, but this was something else with the internal ribbing and the lip on the peg! Freezer might help since the fit is very tight as a result. Any lubrication will inevitably get onto your hands as well. I fitted the peg to the bike first, then put the rubber on - be careful not to bend anything if you do it this way.
    2009 Shiver (White) | UK
    apriliaforum newb newhouse's Avatar
    Aug 2017
    San Francisco, CA, USA
    I think I used to see bicycle shops and places like that use isopropyl/rubbing alcohol to help. A quick internal wipe with a swab and then it should slide on and then evaporate cleanly.
  1. Gen 1 Tuono shift/brake pedals
    By mrk_d in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 11-05-2017, 08:24 PM
  2. Brake Pedal Longer Peg Mod
    By AndyT in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 06-06-2015, 12:01 PM
  3. shift lever and brake pedal adjustments howto
    By nisteporci in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 08-30-2014, 10:32 AM
  4. FS: (UK) RSVR Complete Peg Set / Shift Pedal / Brake Pedal / Rear MC / Brackets / Pin
    By scootz in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 08-28-2014, 10:12 AM
  5. looking for Front foot peg and Brake pedal
    By Flynlo in forum RST1000 Futura (all years)
    Last Post: 02-22-2009, 04:02 PM
