Results 1 to 4 of 4
Thread: What are the two connectors next to the ECU test lead?
    Jul 2017
    Vermont
    Hi all,
    I'm in the process of setting up the Tune ecu for my "new to me" Futura.
    I was curious what the two round connectors (one male, one female) that
    come out of the same wiring harness pigtail next to the ecu connector are used for?
    The only thing I've seen so far is a reference in the maintenance manual for "test leads"
    for all 3 connectors on that harness pigtail.
    Thanks!
    Oct 2012
    SW Idaho, USA
    Those are the quick diagnostic connectors. If you think you have an error, connect them together and turn on the ignition. The dashboard will display a (-XX) code if there is something stored. Some codes don't save, and some only flash on the dash while they are happening. Search around for the list of codes and keep a copy on the bike if you feel the need.
    Jul 2017
    Vermont
    Awesome.........Thanks!
    PA USA
    Quote Originally Posted by vtduc View Post
    and expect to see "1" with the kill switch in the run position and "-1" with it killed. This is normal.
    You'll also use those connectors to erase the "service" reminder that comes on every x miles. Iirc, you'll turn on the ignition with these plugged together and then immediately hold both dash buttons down (10 secs or more) until the reminder goes out
  1. Saying goodbye to the F255 and hello to the A2BF, or how I went from 51s to 57s.
    By DanV990 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-03-2018, 10:46 AM
  2. Bear to the right bro...bear to the right. BEAR TO THE LEFT!!!!
    By Thom in forum General Motorcycle Talk
    Last Post: 08-25-2013, 09:16 AM
  3. whats the plastic plug next to the aircompressor
    By brokenbike in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-23-2010, 11:10 AM
  4. Are these holes next to the spark plugs normal?
    By willpower101 in forum SL1000 Falco Forum (all years)
    Last Post: 02-02-2009, 05:34 AM
  5. are the two blue hoses under the gas tank supposed
    By deputydog95 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-13-2003, 08:19 PM
