Results 1 to 12 of 12
Thread: Sena SMH10R Comm system
    apriliaforum Member rsvrick's Avatar
    LI, NY
    Recently received a Sena SMH10R comm system for Christmas. My only concern is: will I be able to hear anything over my Tuono's exhaust? I have the SC project CF oval slip on, which is kind of loud, but not as loud as something like the the CRT, from what I'm to understand. Anyone running the same basic set up? Does the noise cancelling feature work? How do you turn on the noise cancelling feature?
    '12 Tuono V4 APRC
    '03 Ducati ST4S
    apriliaforum expert InvictaZ3's Avatar
    Apr 2009
    Ashland OR
    Not above 35mph on mine
    apriliaforum expert zedx9's Avatar
    Dec 2003
    Central Oregon
    Maybe get the adapter to use earbuds? I've never used a Sena product but I do know that with my Autocom system, I use earbuds for audio and noise cancellation. With ear plugs and the standard speakers it was difficult to hear at freeway speeds. My plan is to get the Sena 20s (or whatever latest iteration/gizmo they have) and use ear buds.
    apriliaforum Member Ametts21's Avatar
    Dec 2017
    North Carolina
    I have been using the 10s for a couple seasons. It uses the 20s speakers, running in a agv dual evo so not the loudest helmet but not the most quite. I can hear mine at highway speeds on my dorsoduro, I would assume the exhaust isn't as much of an issue compared to wind noise at those speeds. As far as communication with other riders go you can hear no problem at any speeds. I would recommend the 10s or 20s over the R forctge reason of they have better speakers and better range although not as sleek as the R
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    apriliaforum expert spencer's Avatar
    Aug 2004
    New Oxford, PA
    I have the 10S, as do 3 of my riding buds....cant say enough good things about it. Im on a 04T, akra slipon....so not very loud. (motorcycle mechanically) Noise cancellation is superb, most people have no clue Im riding a motorcycle while im talking to them on the phone. Intercom is crystal clear for around 1/3 mile in town, 1/2 mile country. Battery that lasts well over 10 hours of continuous use. If I had to complain about something it would be the radio, it simply does not pull channels like a car. I tend to use pandora or some internet based music if riding by myself or commuting. I would also recommend against VOX intercom, annoying when singing along with a song and it cuts out and goes into intercom mode.
    2004 Tuono
    Dec 2017
    North Carolina
    Quote Originally Posted by spencer View Post
    I love mine as Well! I guess we should of clarified for the OP that as far as I know the noise cancellation is for the output for calls, I don't think it's dynamic for the listener like say Bose noise isolation headphones are. The only complaint I have is the pairing method seems to be hit or miss at times, if it's the same people you always pair with it works okay but I've spent many minutes sweating my ass of in leathers trying to get paired but it does eventually work. "Intercom failed try again later" haunts me. And I wouldn't waste time with any other brand besides SENA
    Apr 2017
    Richmond, VA
    I have the smh10 and haven’t had a problem. I commute about 40 miles each way with gutted 09 tuono exhaust. I wear a shoei qwest. I’ll wear a pair of acoustic ear plugs to cut down on the wind but I’m always able to hear the headset even above 100. The noise cancellation is impressive as I’ve called into conferences and nobody was any wiser unless I really opened the throttle to pass a grandma or two.
    Aug 2004
    New Oxford, PA
    Quote Originally Posted by Ametts21 View Post
    agreed. Although we actually broke out the instructions last time and it worked fairly quickly. Once all paired up (4 to our group) we dont turn them off, even if we stop for lunch or to sight see the SENA stays on and connected to the other units. I have a power outlet in my tankbag, usually connect charger after 10-11 hours of use.
    2004 Tuono
    Jan 2018
    South TX
    Jeez, I guess I need to try a Sena. I’m half-deaf from a lifetime of concerts, loud cars/bikes, and guns. The two helmet communication systems I’ve tried are worthless above about 40 mph, except on my 650 Versys, which is so quiet to begin with that it might as well be electric. On anything with even a moderate exhaust note I can’t hear a damned thing even with the volume maxed out.
    Dec 2017
    North Carolina
    Quote Originally Posted by snakeeyes7 View Post
    Jeez, I guess I need to try a Sena. Iím half-deaf from a lifetime of concerts, loud cars/bikes, and guns. The two helmet communication systems Iíve tried are worthless above about 40 mph, except on my 650 Versys, which is so quiet to begin with that it might as well be electric. On anything with even a moderate exhaust note I canít hear a damned thing even with the volume maxed out.
    Always recommend SENA. Best out there try them, before you write off bluetooth coms
    Jan 2018
    South TX
    Thanks, will do. I ride with a neighbor and other than a good set of twisties I’ve found that I enjoy just BSing with him about the road, the week, our families, etc. It kind of sucks when every other word out of my mouth is “WHAT?”
    Dec 2017
    North Carolina
    Thanks, will do. I ride with a neighbor and other than a good set of twisties Iíve found that I enjoy just BSing with him about the road, the week, our families, etc. It kind of sucks when every other word out of my mouth is ďWHAT?Ē
    Sena 10s is a good choice but the w0s is probably the best bang for the buck st the moment as the new model just came out
  1. SENA SMH10R Bluetooth headset KIT(2)
    By Mbyrne93 in forum Other Stuff For Sale
    Last Post: 11-30-2017, 11:49 AM
  2. SENA SMH10R (2) Bluetooth Headset
    By Mbyrne93 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 11-21-2017, 04:24 PM
  3. Beo Comm System
    By BeoLuva in forum Aprilia and Piaggio 500cc
    Last Post: 09-02-2007, 04:34 PM
  4. EVO Comms System
    By Flashfish in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 06-06-2007, 08:05 AM
  5. Atlantic Comm System
    By AtlanticGuy in forum Aprilia and Piaggio 500cc
    Last Post: 09-28-2004, 03:37 PM
