Results 1 to 6 of 6
Thread: Okay I give up
    Jul 2008
    Mare Island, Ca. USA
    Okay I give up
    Iím not having success accessing the front spark plugs for replacement. I am not having success finding information about it here either. Iíve gotten to the air box but havenít been able to extract it. All of the bolts are out but it wonít budge. Help please.
    Dadsafrantic
    2015 Red Caponord #64
    You don't have to remove the airbox, just fart about with the rad mount a bit from memory.
    Professional Goat Burster.
    apriliaforum Member Patrick Morin's Avatar
    Jan 2014
    Quebec,Canada
    There is a little door with a screw,very easy! No need to remove the air box.
    Dec 2014
    Chelmsford, Essex, UK
    Just remove the plastic bracket below the radiator. There’s a screw below the radiator and another near the water pump. They have spring clip nuts behind, which is fine as long as they aren’t rusted solid like mine we’re. I ended up cutting off the bolt below the radiator. Despite my GT having a service history the bracket had clearly never been off the bike and the two front plugs were all but invisible under a thick layer of crud when I eventually got it off.
    Jul 2008
    Quote Originally Posted by dadsafrantic View Post
ID:	348650Click image for larger version.
ID:	348651Click image for larger version.
    Thanks everyone. As you can see from the pictures they donít look like they have 22,000 miles. Or do they?
    Dadsafrantic
    Jul 2008
    I lied. 22.9k here are chain pins from the chain and sprockets change I just did at the same time. Original chain. Click image for larger version.
    Dadsafrantic
  1. Who would give up their Tuono for the wife
    By Big Simp in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-30-2015, 01:16 PM
  2. Ok, I give up!
    By BigGlen in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-23-2003, 08:48 AM
  3. Ok, I give up!
    By BigGlen in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-21-2003, 06:57 AM
  4. I might have to give up the Mille for this
    Last Post: 08-29-2003, 03:12 PM
  5. Giving up on the RS, traded it for a CBR250RR
    By Tokyo Rider in forum RS125 Euro-archive
    Last Post: 05-21-2003, 01:29 AM
