Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Headlight Uprate?
    apriliaforum expert Ricardo J's Avatar
    Sep 2017
    Far Eastern Pacific
    Headlight Uprate?
    After putting in some extended mileage on dark backroads I'm pondering an upgrade to the Rally's headlights. I suspect our stock H11 bulbs are not of the highest quality so swapping to more efficient H11 bulbs is a reasonable first step. The goal is not fashion, "blue", or "HID-look", just more lumens on the road in a proper spread. The new bulbs must not be short-lived, either.
    I do keep an eye on developments in LED bulb technology, and understand the challenges of designing an LED bulb to work well in a reflector and lens assembly made for halogen bulbs. It would be outstanding if a breakthrough could me made with this tech. More light with less power draw and less heat would be fantastic.
    apriliaforum expert dadsafrantic's Avatar
    Jul 2008
    Mare Island, Ca. USA
    my reflectors are torched. completely burnt. i would not do much except maybe see what is available for an led swap. i'm trying to get a picture in my mind of doing a retrofit led projector install. time keeps getting in the way.
    Dadsafrantic
    2015 Red Caponord #64
    2008 Mana Grey #81, hyperpro springs and shock, gpr furuore, rigid lights, bark busters, kaoko throttle lock, puig touring screen
    Sep 2017
    Far Eastern Pacific
    Extent of Condition
    Interesting...is that a poor coating batch or a common mode failure of this component? It has me wondering about attaching a heat sink to the back side of these reflectors, to reduce temperatures. But plastic is a pretty lousy heat conductor anyway and that might not do much for the reflectors' peak temperatures. Darn!
    I did find this pretty cool resource in the UK who can re-plate headlight reflectors, including plastic ones! http://www.vmclimited.co.uk/index.php
    Sep 2017
    Far Eastern Pacific
    Tweaking Aim
    Turning the elevation adjuster screw ~1.5 turns clockwise made a good improvement in beam throw, and oncoming drivers aren't objecting. It's not very easy to access this adjuster, though! I just added an 8mm ratcheting flex head combo wrench to my toolkit for future tweaking.
    apriliaforum Junkie SudEst's Avatar
    Oct 2016
    Melbourne, Australia
    Headlight Uprate?
    Well what did I discover today ...
    Now to see how a warranty claim goes. Thankfully I have the OEM lamps so they wonít get me on that one
    Sent from my iPhone using Tapatalk
    Jul 2008
    Quote Originally Posted by SudEst View Post
    I imagine that they will tell you what they told me.
    Sent from my iPad using Tapatalk
    Dadsafrantic
    apriliaforum prov-nov Def151's Avatar
    Sep 2017
    New Hampshire
    For the vision impaired and possibly the dumb (me), what did you discover? I donít see it. Iím in this thread because I wonít ride after dark because the headlights do little to brighten the night.
    2017 RSV4RR Akrapovič slip/ aRacing ECU software
    Oct 2016
    In this close up you can see how the heat from the lamp has caused the plastic underneath to burn and itís discoloured
    Sep 2017
    Far Eastern Pacific
    One Hump Or Two?
    SudEst, is this scorching on both sides or just one so far? How much running time do you have on them?
    The fundamental issue seems to be a poorly-plated reflector, and who knows if a warranty replacement would be any better quality? Assuming it isn't, the best available solution would be an effective H11 LED bulb that reduces heat output to the reflector. I'm going to pursue this option now.
    Oct 2016
    Headlight Uprate?
    Itís on both sides but Iíve shown the left as thatís the worse of the two. Hard to find an LED that is effective with those reflectors I believe.
    But by all means let me know if you do. As I commute year round I do actually need effective headlights, not just to be seen but to see the road and illuminate signs etc
    Sep 2017
    Far Eastern Pacific
    Effective Headlights
    In 100% agreement that these are needed, meaning more lumens on the road in a smooth pattern with minimal glare to other drivers. Less heat on the reflector would be icing on the cake! At the moment the most advanced H11 LED might be PIAA's new G3 series which debuted late in 2017. They claim major progress in getting the diode and column geometry to approximate a halogen's filament placement; apparently the column in thinner to mimimize dark spotting plus it can be "clocked" to match the stock bulb. All very nice claims! But claims won't light the road. Still, I'm tempted to bite the bullet and see what can be done with a pair. I'll never miss the money. When I'm dead.
    Oct 2016
    Quote Originally Posted by Ricardo J View Post
    I just went to the website. Big claims and a pricetag to match!
    The equivalent product from Philips is similarly expensive. And it still carries a disclaimer that it's not road legal.
    As if I need to make it any easier on some moto-hating highway patrol officer...
    In fact, Philips don't officially list LEDs for motos and I wonder if it's because of a packaging problem with heat sinks etc?
    You'll find some LED bulbs will come with a disclaimer saying modification may be required.
    Oct 2016
    Oh and what is Philips is trying to tell us in this picture?
    "nine out of ten sleaze bags agree, kerb crawling is made easier with Philips..."
    Sep 2017
    Far Eastern Pacific
    Headlight Revolution dot com
    I found these two videos on automotive LED technology really enlightening!
    Performance test of 15 bulbs: https://www.youtube.com/watch?v=SQF5ESBHLrw
    Tech tutorial: https://www.youtube.com/watch?v=Sonh4lHu4XE
    Based on all of that I think the Supernova V3 is in pole position for my project. Amongst the best in overall lumens and an excellent beam pattern.
    Oct 2016
    Now to see how a warranty claim goes. Thankfully I have the OEM lamps so they won’t get me on that one
    Happy to report that this was approved as a warranty claim, and better still they have replacement units in stock so I'll be getting them swapped over next week.
  1. Headlight-melting or broken???(pics now)
    By KaneRSV in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-23-2006, 02:23 PM
  2. headlight
    By akey1234 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-02-2003, 08:01 AM
  3. SL1000/RS50 w/Headlight Covers
    By BikerGeek in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 06-03-2003, 07:16 AM
  4. Headlight Covers
    By BikerGeek in forum SL1000 Falco Forum (all years)
    Last Post: 06-02-2003, 10:01 PM
  5. Headlight adjustment
    By UnsavedOne in forum SL1000 Falco Forum (all years)
    Last Post: 04-17-2003, 07:02 AM
