Results 1 to 4 of 4
Thread: Headlight Uprate?
    Sep 2017
    Far Eastern Pacific
    Headlight Uprate?
    After putting in some extended mileage on dark backroads I'm pondering an upgrade to the Rally's headlights. I suspect our stock H11 bulbs are not of the highest quality so swapping to more efficient H11 bulbs is a reasonable first step. The goal is not fashion, "blue", or "HID-look", just more lumens on the road in a proper spread. The new bulbs must not be short-lived, either.
    I do keep an eye on developments in LED bulb technology, and understand the challenges of designing an LED bulb to work well in a reflector and lens assembly made for halogen bulbs. It would be outstanding if a breakthrough could me made with this tech. More light with less power draw and less heat would be fantastic.
    Jul 2008
    Mare Island, Ca. USA
    my reflectors are torched. completely burnt. i would not do much except maybe see what is available for an led swap. i'm trying to get a picture in my mind of doing a retrofit led projector install. time keeps getting in the way.
    Dadsafrantic
    2015 Red Caponord #64
    Sep 2017
    Far Eastern Pacific
    Extent of Condition
    Interesting...is that a poor coating batch or a common mode failure of this component? It has me wondering about attaching a heat sink to the back side of these reflectors, to reduce temperatures. But plastic is a pretty lousy heat conductor anyway and that might not do much for the reflectors' peak temperatures. Darn!
    I did find this pretty cool resource in the UK who can re-plate headlight reflectors, including plastic ones! http://www.vmclimited.co.uk/index.php
    Sep 2017
    Far Eastern Pacific
    Tweaking Aim
    Turning the elevation adjuster screw ~1.5 turns clockwise made a good improvement in beam throw, and oncoming drivers aren't objecting. It's not very easy to access this adjuster, though! I just added an 8mm ratcheting flex head combo wrench to my toolkit for future tweaking.
  1. Headlight-melting or broken???(pics now)
    By KaneRSV in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-23-2006, 03:23 PM
  2. headlight
    By akey1234 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-02-2003, 09:01 AM
  3. SL1000/RS50 w/Headlight Covers
    By BikerGeek in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 06-03-2003, 08:16 AM
  4. Headlight Covers
    By BikerGeek in forum SL1000 Falco Forum (all years)
    Last Post: 06-02-2003, 11:01 PM
  5. Headlight adjustment
    By UnsavedOne in forum SL1000 Falco Forum (all years)
    Last Post: 04-17-2003, 08:02 AM
