Results 1 to 4 of 4
Thread: Clattery engine.
    Aug 2017
    manchester UK
    Clattery engine.
    Hi all.
    Been going through the Falco, top to bottom. Picked up a low mileage RSV engine and popped it in, (I wish it was that easy!)
    No doubt about it, my original engine is much more clattery than this one, although it performed excellently. Very good fuel consumption, usually a sign that things are worn if it gets thirsty, absolutely no smoke on accel OR decel, started on the button with a steady even tickover, usually a good sign that valves are OK.
    Now I have the time, I'll be taking a look inside my original engine. Anyone any pointers to look for? Its the kind of clatter that wold suggest a worn bush or bearing, might be nothing more serious than valve clearance too wide.
    So, basically, what areas should I concentrate on?
    Cheers
    May 2007
    Durham U.K.
    The first thing id check is the cam chain tensioners, if theyre weak they will cause clattery sounding motor.
    Aug 2017
    manchester UK
    Forgot to add that it has 35K miles on it. CCT's do sound a likely candidate, thanks for that, might be a very easy fix! Keep on with the pointers, might as well do the job properly. Had in inking to do the gen 2 head swap while I've got it out. Might be putting a shout out for a pair in a little while....
    Cheers.
    Jul 2009
    Last spring had a spanking new Z900 demo when my Falco was at the shop. At idle didn't even notice the kwak was running. My push bike makes more noise. That thing was so silent compared to my clunky and rattly Falco.
  1. Removing Rear Engine Mounting Bolts
    By rts571 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-24-2013, 09:19 AM
  2. New Aprilia:What engine do you wan't?
    By Kobie in forum Professional Racing Discussion
    Last Post: 07-16-2003, 10:27 AM
  3. Engine Oil
    By Sdave2002 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-14-2003, 01:04 PM
  4. Anyone got any engine sound or videoclip of RS 250 ??
    By Jordan32110 in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 05-06-2002, 12:55 PM
  5. Two new Aprilia engines on the way
    By ed apriliaforum com in forum Professional Racing Discussion
    Last Post: 06-26-2001, 08:52 PM
