Results 1 to 13 of 13
Thread: TSS Slipper/Antihopping clutch
    Jan 2013
    U.K.
    After installing the TSS unit, I have struggled to get the bike into neutral.
    After some reading and discussion, I understand I need to be quite careful about the clutch pack height. To this end, I have spare parts that should allow, perhaps at least, some fine adjustment. I expected to find details re pack height in the instructions..There is nothing specific however..
    Can I get some input from others who have worked with this installation and had tune the adjustment please...? ( gen1 bottom end)
    ( I realise this is an issue with a number of approaches..Please note, I am seeking clutch pack dimension guidance in this case....)
    Thanks for looking...
    Sep 2009
    Hi Tim, merry Christmas mate.
    The tss clutch is the same as the Sigma, if you go on the sigma site you should be able to download the information there.
    Oct 2009
    Tim,
    Read through this post there is an bit about the deck height and the way the clutch plates are set up Richard aka dog78 or Vergil on here in the gen2 section has his working perfect now so good advice from him
    http://rsvr.net/jmhs-1060-big-bore-p...opic25873.html
    Jan 2013
    U.K.
    Great- thanks guys !
    Jan 2015
    20 Harwood Place Kingsworthy winchester Hants SO237PS
    Hi Tim, sent you a pm.
    Sent from my E5823 using Tapatalk
    Jan 2013
    U.K.
    Aye, got it. Sorry to be a bit slow on the uptake...!
    Roma, Caput Mundi
    will update my V2 Tuono racebike to TTS/Sigma soon as well... so i need infoes too!
    www.gabroracingteam.it
    Visit my FB page and like it!
    Dec 2012
    Paimio, Finland
    Order for TSS:
    Engine.................................Pressure plate
    F|S|F|S|S|F|S|F|S|F|S|F|S|F|S|F|S|F
    pressure plate lift with stack in place. The closer to 1.2 mm you can get the better. Minimum 0.5 mm. Mine is 0.7-0.8 mm with used plates.
    Mille Aarrr -02 & KTM 625 SXC -05
    Jan 2015
    Hi Gabro, pm sent.
    JMH I used new Ferodo fibers but only managed to get .9, maybe with new steels aswell I may have got to 1.2, but it works great and you are going love it, superb bit of kit.
    Jan 2013
    U.K.
    Can I get confirmation where to measure the clutch pack. My vernier wont go down the TSS tech suggested holes but I may not be using the right ones...!
    Can anyone confirm if I go this right...?Click image for larger version.
    Jan 2013
    U.K.
    Changed the oil to a semi ( from fully synthetic- dont trust FS oil, dunno why I went for it. Nothing but trouble...!)
    Arranged the plates in the correct order. Clutch jet swapped out for the better version. New clutch pack fitted, and checked spec as per TSS set up crib sheet (1.1mm)
    Does it want to go into neutral...? Does it feck !
    Conclusion..TSS slipper clutch screws up the operation of your bike's cluch..?
    I can't help you with your clutch but I am puzzled by your mistrust of synthetic oils. They are superior in every measurable way to conventional oils. Why use a semi synthetic? If synthetic is so bad, why do you want any in there.
    I use fully synthetic oils in everything I own. Even my lawn mowers.
    Jan 2015
    Hi Tim, mine has the same slipper clutch, although it never been great to get in Neutral, it's worse when cold but still not ideal. Your stack height is bag on. I have also got to get to the bottom of the problem.
    I am thinking of putting the original clutch leaver in because I believe it has more travel than the aftermarket one. If I reduce the slack in the leaver it works fine but as the engine warms it takes up the slack and slips.
    We also had a problem with a Surflex kit and a TSS slipper combination.
    But we got it to work by taking the funny spring plate and moving it to the middle and putting to steels together, so the clutch order has a fiber to start and a fiber to finish against the pressure plate. I have the bike apart at the moment but I will let you know how I get on with the leaver swop. As far as I can see you have fitted it correctly and close as dam it to the height . 6 to 1.2 mm, they say 1.2 optimum.
    I could only get .9, but it works great like you Neutral is still difficult.
  1. TSS Slipper Clutch Question
    By Andrew Bright in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-31-2014, 08:32 AM
  2. difference between slipper clutch and antihopping clutch?
    By AceOfSpades in forum General Motorcycle Talk
    Last Post: 08-06-2008, 03:15 PM
  3. Slipper(ing) clutch
    By kwoody51 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-07-2005, 07:51 AM
  4. Slipper clutch Tuono ???
    By link in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-08-2003, 06:21 AM
  5. skid marks! - slipper clutch ?
    By evander13 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-20-2003, 08:47 PM
