Results 1 to 5 of 5
Thread: Heated hand grips
    Dec 2017
    Romania
    Heated hand grips
    Hello everybody,
    Last spring I have bought a beautyfull 2010 Aprilia Shiver 750. I like this bike very match, but one of the features that I miss on my Shiver are heated hand grips, this is why I decided to install some aftermarker chinese heaters, like the one in the picture.
    I have removed the grips from bougth ends of my handlebar, but I'm not sure how to install the heater on the throttle tube.
    Did any of you guys solved this problem?Click image for larger version.
ID:	348293Click image for larger version.
    Jul 2007
    Kapiti, New Zealand
    I have only ever fitted heaters integrated into the grip.
    I presume they would wrap around the throttle tube, then the grip would go around that. However, the fit is very tight and cannot slip. Also, the left hand heater would lie directly on the metal handlebar and would lose a lot of heat.
    Frodo
    2015 Shiver
    New Zealand
    May 2012
    Cherryville, NC
    Thin shrink wrap tubing or a layer or 2 of electrical tape on the handlebar will help hold the heat in the left side grip.
    2008 Aprilia Shiver
    2007 Moto Guzzi Breva 1100
    Dec 2017
    Romania
    "Thin shrink wrap tubing or a layer or 2 of electrical tape on the handlebar will help hold the heat in the left side grip."
    Thank you. I think it's a good idea.
    apriliaforum newb Puntas's Avatar
    Aug 2017
    Alexandria
    You'll have to make your throttle tube completely smooth. You can shave off the ridges with a sharp knife or use a bench grinder.
  1. How to wire up heated hand grips.
    By Tarrasque in forum SL1000 Falco Forum (all years)
    Last Post: 07-04-2008, 05:34 AM
  2. Heated Hand Grips
    By jv8358 in forum Aprilia and Piaggio 500cc
    Last Post: 02-14-2005, 03:05 AM
  3. Hand grip
    By jd_johnson in forum Aprilia and Piaggio 500cc
    Last Post: 02-17-2004, 10:34 PM
  4. Hand grip suggestions
    By mrpete64 in forum ETV1000 CapoNord (2001-2007)
    Last Post: 01-05-2004, 05:26 PM
  5. Hand Grips
    By mayflowerjeff1 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-15-2003, 11:15 AM
