Results 1 to 9 of 9
Thread: questions on reinstalling clutch cover.
    Aug 2014
    Washington
    Hey guys, just a couple quick questions. According to the Aprilia manual there are different torque values for the clutch cover. The torque number are 8.1ft lb for the M6 bolt and 14ft lb for the M8 bolts. Normally the same torque values are used for uniform compression of the gasket...not that there is much compression with the factory gasket...it is pretty thin. For all you guys that have had there’s off, are those the numbers you used. Also any particular sequence used for the clutch cover. Thanks guys! Just trying to fix this coolant weep hole leak situation!
    The manuals values are correct. No specific sequence other than tighten them evenly. Two or three stages helps with that.
    Aug 2014
    Washington
    thanks KZ...for some reason I didn't get any notification of your response. I went in to put the clutch cover back on and noticed my oil pump gear was missing a bunch of teeth....so I had to tear out the clutch basket and all as well as the oil pump to replace the gear. A little strange. Hoping it all turns out ok! \
    Do you know what happened to the teeth?
    Apr 2015
    Nor Cal
    Hope it wasn't meth...
    Aug 2011
    Wake Forest
    as already said... I would be looking hard for those teeth.
    @dtrides... thats funny
    Aug 2014
    Washington
    I really hope it isn't meth! haha As far as the teeth go if I had to guess I would guess the oil pump ate them up. it is a fairly soft plastic gear and it runs off another plastic gear mounted on the back of the clutch basket. I looked everywhere I could too find even the slightest trace of plastic, but found nothing. I ended up removing the oil tank and I could not believe the amount of sediment and sludge in the bottom. If you haven't ever cleaned out your oil tank maybe consider it next oil change. I was surprised by what I found in the tank...but the plastic teeth were nowhere to be found.
    Aug 2014
    Washington
    Jun 2006
    Columbus, GA
    Quote Originally Posted by inacoma View Post
    Really? in the oil tank? I gotta look in mine.
    2007 Tuono 1000R Factory
    Cored OE Racing CansMap2Pazzo Knock-offs15-40AF1 Link PlatesAprilia Sliders
    ProTaper Mini-LowClear Signal Lenses
    Retired - DJ, Turntablist, Creator and Mixologist.
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
  1. Silly question on topping up clutch fluid
    By RSV_Ecosse in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 05-08-2008, 02:39 AM
  2. White watery marks on clutch cover...??!
    By burntout in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-13-2007, 03:36 AM
  3. Cogs in clutch cover question
    By lilmac7 in forum RS125 Euro-archive
    Last Post: 09-04-2006, 07:09 AM
  4. Help - stripped thread on Clutch Cover
    By soo33y in forum RS125 Euro-archive
    Last Post: 04-09-2006, 09:05 PM
  5. question on clutch and electronic shifter
    By sreavis in forum RS250
    Last Post: 05-31-2004, 08:31 PM
