Results 1 to 6 of 6
Thread: Aprilia 200 won't start - brake lights not working either.
    Dec 2017
    Bay Area
    Hello, I am new to the forum and Aprilia. Just got a 2008 Aprilia 200 Scarabeo. Intermittently the scooter will not start. When this happens the brake lights also do not function. All other lights, gauges, etc. are working.
    I understand the scooter must "think" at least one brake is applied before the starter button will work. When the brake lights do work it starts up fine with either brake applied. Is there some type of electrical relay between the brake levers and the brake lights? Any help appreciated. Thanks.
    NC
    I would check the switches on your break lights. They are on the brake levers and when you pull on the lever they pop out and complete the brake circuit. It could also be the bulbs aren't seated correctly so you get an intermittent connection. Here is a link to the switch.
    Sep 2011
    Orange Tx
    The only relay in the starting circuit is the starting relay. The break light switch is in series with start button and starting relay.
    Do as I say, not as I do
    NC
    If the switch is bad then the system won't know that the brake is being pulled and will think its trying to start without the brake on.
    Clearwater, Fl
    Yep - The system is simple and does not think just uses the brake light to provide power the the field coil of the starter relay. If the bike spent a lot of time out in the rain chances are that the brake light switches are sticking and need some attention. Sometimes just a little WD40 is all thats needed to clean them up.
    ontario
    yes and if thats the case then its time to grab some permatex dialectric grease to keep the water out
  1. Aprilia caponord ETV 1000 right signal light not working
    By greyceller in forum ETV1000 CapoNord (2001-2007)
    Last Post: 01-20-2011, 05:15 AM
  2. sr50 lights and brake light not working
    By William_SR50 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 01-02-2011, 10:37 AM
  3. Rear Brake Light Not Working?
    By 98 peg in forum Pegaso 650 Cube and IE
    Last Post: 06-16-2005, 08:20 AM
  4. Bike won't Start - Neutral light not showing
    By Z o l t a K in forum RS250
    Last Post: 03-20-2004, 02:12 AM
  5. brake light not working
    By bernie in forum Pegaso 650 Cube and IE
    Last Post: 07-27-2003, 04:36 PM
