Results 1 to 10 of 10
Thread: more torque?
    Aug 2011
    United States
    more torque?
    This one's for the guys who have experience building V60's. I'm hoping Micah will chime in here. The question is, would it be possible to get a Futura to make torque numbers in the 80's? If so, what would it take? Big bore, big valve heads? Sure would be fun.....
    PA USA
    yer not the 1st to ask the question. Dunno if the service is still available though.
    http://www.apriliaforum.com/forums/s...0-Big-bore-kit
    37 miles E. of ATX, TX USA.
    1060cc, stock ported heads, cam timing 102/105, stock throttle bodies, stock intake stacks, H-Pipe or equivalent to replace breadbox underneath and some time mapping on dyno. I was able to get 74 ft/lbs on my last Tuono with similar mods on stock 97mm pistons.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Aug 2011
    United States
    Thanks guys! If I could only have one bike it would be a super Futura. This thing does everything well. With more power it would be even better!
    So...if power is what makes you smile combined with a Futura, I might suggest a bit different route. 1060cc pistons, squish at .9-1.0mm, cams 106/109, Gen2 late model big valve heads, gen2 57mm throttle bodies, RSVR intake stacks in stock RST airbox (easy mod) with 440cc injectors.
    A turbocharged RST is another option but, trust me this rabbit hole has a very deep bottom. I'd use an Aerocharger VNT type turbine, no more than 8-10 psi boost, single throttle body with common plain manifold and air to water charge cooler. If you feel a reduction in compression ratio is required use stock Capo Piston, provided you do not go crazy with the boost and detonate it...saves a a grand on your build. Fueling can be managed by PCV type power commander with manifold pressure reference added for blended alpha/n tuning. I rode an FJR1300 set up this way...HUGE smiles!
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Aug 2011
    United States
    I really like the naturally aspirated route. Is there still a source for H pipes?
    Not that I know of. Saw one go for $500 the other day on eBay...holy shit. I still have my original prototype...just in case I ever need it for myself
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Mar 2012
    SE corner of the NW
    Quote Originally Posted by tz97 View Post
    This guy worked up plans, a jig, and made some....
    http://www.apriliaforum.com/forums/s...ghlight=H-pipe
    JD
    '01 Futura
    Sydney, Australia
    So if you did go with a single throttle body, what size would be equivalent flow compared to our 57's?
    If you wanted a really really deep rabbit hole, would you go larger valves on both in/out sides and would you go billet cams with longer duration?
    ApriliaPista
    Mille Tech
    51-57mm is plenty big for 200 bhp if turbocharging a V990. Pre or post turbocharger compressor. For best response and tuning it seems to me the way to go. Simplification when adding complexity is good too.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  1. The MT-09 has a lot more torque than the 1000 Tuono?
    By fredaroony in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 04-08-2016, 02:17 PM
  2. More low down Torque required
    By RSVV60 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-05-2011, 03:34 PM
  3. I need more torque
    By ShifterZX in forum RS125 Euro-archive
    Last Post: 01-22-2007, 12:12 PM
  4. Does the MV really have more torque?
    By Itsallgood in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 01-13-2007, 09:06 AM
  5. Need More Power and Torque
    By paulphin2002 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-21-2005, 12:33 AM
