Results 1 to 15 of 19
Thread: Anybody running Taylormade pipes?
    Sep 2013
    Corona Del Hood Oakland CA
    Any of you resourceful gents out there running Taylormade pipes with a non H-pipe connection.
    My bike is running 110 Miles on a tank with the rear of my bike smelling like a kentucky coal mine.
    Any suggestions?
    Jerry.
    37 miles E. of ATX, TX USA.
    Fuel pressure regulator is toast or coil pack(s) have failed. Most folks get WAY more miles than that out of a tank on an RST.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Mar 2012
    SE corner of the NW
    200+ on mine with pretty spirited riding. Staintunes, no H-pipe.
    JD
    '01 Futura
    Sep 2013
    If the Coil/s are/ have failed, would'nt I see that on the Fault codes?
    Does no fault readings point me towards the Fuel Pressure regulator?
    Also, Easy way to test the coils?
    Waddyathink?
    apriliaforum Junkie Corsehf's Avatar
    Jul 2006
    Worcestershire - UK
    Quote Originally Posted by Afrodog View Post
    Waddyathink?
    Are you running the 05 Map?
    If so, have you done the FPR mod?
    Failed coils should throw up fault codes but some have reported not.
    If you have a spare good spark plug, pull the HT leads, connect the spare plug into each lead (one at a time), earth the plug electrode onto the engine and hit the starter and check for a spark.
    I get 225 - 230 miles per tank at an average of 55mpg
    Andy
    Current: 2002 Futura RST in Silver
    Datatagged, 05 Map, Metal QD, H Pipe, Bef Cans, RSV De-restrictive Snorkel, RSV Forks & Brakes upgrade, NGK DCPR8EIX Iridiums, Earthed Throttlebodies, FPR Mod, Vee Max Starter Solenoid with uprated cables, FH008EE RR & Wiring Mods, NWS Hugger, Oxford OF691 Touring Hotgrips, Accessory & USB Sockets, HID Headlight, Pirelli Angel GT's
    Up in Flames: 2001 Futura RST in Blue
    Datatagged, 05 Map, Skidmarx DB Screen & Hugger, K&N Filter, Brown Connectors soldered, R&G Hotgrips,
    Acumen DGV, Scottoiler, Accessory Socket. BikeVis Bullets
    I just had a Capo on the dyno with two bad coils....and zero reported errors. Same efi as RST.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Sep 2013
    Ok guys, Thanks this is all good information.
    Yes on the 05 map
    Yes on the Mod.
    From here, As a process,
    1. Pull the leads off the existing plugs (New by the way) Ground and check.
    2. Replace the FPR, (I happen to have a spare parts bike). Is that an easy swap, from the diagram, looks simple?, anything to be wary of?
    Thanks Gents.
    Sweden, Linköping
    There is a better way to check the coils with the engine running. Make a search in this forum.
    apriliaforum expert flying fox's Avatar
    Apr 2008
    Stockton-on-Tees,UK
    Check your CO2 emissisions - they need to be 2.7% when running the FPR mod.(this is about as low as you can get them).I was getting poor economy as mine was at 6% !!!!- since changed and I get 50mpg now.
    04 Silver,FPR Mod,Derestrict Airbox,Mille Boot,Reg/Rec Mod.,05 Map,Heated Grips,Smoked Screen,Beftura Forks,Scottoiler,Stone Chips,Scratches...
    The Art of Bodge-It Never Fails.
    Sep 2013
    Deefred,
    Can you please be a little more specific. there seems to be lots of conversation around coil tests, but not seeing a straight process description
    Jerry
    Sweden, Linköping
    For checking that you get a spark on each spark plug, the best is to do it with a running engine.
    Just start the bike and then unplug one*LT*lead of an ignition*coil.
    If it starts to run on one cylinder it means the other spark plug on the same cylinder is not firing.
    Do this for all coils.
    If you are uncertain how the engine sounds like with only one cylinder running, disconnect both coils on the same cylinder.
    Do not disconnect the high tension leads only the low tension ones.
    Coils tend to have the highest failure rate, but also a bad HT lead, bad*coil*connector*or bad spark plug can cause this.*
    Sep 2013
    Ok, Report back to all you helpful lot.
    Took humpty apart and I could not determine a bad coil from Defred's process. No error messages either.
    Went ahead and installed a set of Almost new Magnacore leads from my Bannana shaped parts bike.
    (That's another story) and presto, Bike runs 75% better.
    It's still stinky out back, Speznas and I agree that another sit down with Tune ECU and we can probably lean her out a little more
    Fuel trim is currently at 38. with no other deviations from 05 Stock.
    Anybody with open pipes have opinions around where this number should be?
    Jerry.
    Sweden, Linköping
    Did you really disconnect the low tension connector from the coil? It will generate either a flashing EFI light or a code with the diagnostic cables connected.
    Sep 2013
    Deefred,
    Sorry, my simple feedback,
    Detached each coil one at a time. Each coil brought back an error code reflected by its correct number. The wiring was correct. Could not determine any bad coil, each one made a small difference. Once all was swapped out with the Magnacores, everything seemed to run better.Only difference was that prior to the project error code was -1, afterwards +1.
    Original leads felt stiff. Routing them was btw, a complete pain in the ass.
    Thanks for the help.
    Jerry.
    Sweden, Linköping
    O.K FYI the +1 and -1 is only the position of the kill switch (Unless there is another fault in the system. It takes a few seconds for it to change code if you flip the kill switch.
  1. Sound Bite for Taylormade Pipes?
    By dugkim in forum RST1000 Futura (all years)
    Last Post: 05-20-2005, 05:30 PM
  2. Replies: 3
    Last Post: 12-14-2004, 10:24 PM
  3. Anybody run a Tigcraft?
    By hybrid-RS50 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-10-2004, 04:32 PM
  4. Replies: 0
    Last Post: 08-01-2004, 02:27 PM
  5. run stock pipe with EVO air box
    By pan in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 07-01-2004, 06:21 AM
