Results 1 to 10 of 10
Thread: Adjustable Trile Clamps
    apriliaforum Junkie NitroArgi's Avatar
    Athens-Greece
    Hello all,
    I was wondering if someone knows which racing triple clamp will fit a 1999 RSV...Looking to ugrade mine for an adjustable version...any idea?
    Flyhammer, but you pay the price for a new cnc machined triple clamp set.
    If you have Showa nonradial forks, options are limited Early rsvr yokes for showa nonradial forks have 33.5mm offset instead of 35mm on the old Mille's. You will lose steering lock though. RSV4 has more modern 30mm offset, but that's with clamping 53mm below 51 on top and again no steering lock.
    I myself was hoping that an rsv4 factory aluminium stem will fit in our bottom yoke. RSVR Factory stem doesn't fit as it's 41mm versus 39mm on our bottom yoke. So if anybody knows what bottom stem diameter is on RSV4 Factory/RF..... the guy on ebay who sells one can't be bothered to measure it properly.
    Also, some time ago some French bike breaker had a 53mm bottom yoke for sale with an aluminium stem. When I contacted them it was suddenly sold....
    Athens-Greece
    Attack Performance said no, Robby Moto the same and IMA Racing Parts...I was really hoping that the RSV4 parts will fit but noone knows if they will
    apriliaforum expert jess67's Avatar
    sth oz
    Check out Gilles Tooling
    Sep 2006
    Sydney, Australia
    Harris in UK should do adjustable triples I think
    I used a German company 10 years ago for a project GenI,although not adjustable, but you just told them what you wanted and voila 6 weeks later it showed up, should be plenty reputable machine CNC shops that can make you what you want.
    ApriliaPista
    Mille Tech
    Sep 2006
    Sydney, Australia
    triple clamps
    Not Aprilia forks but mounted on GenI
    With custom clamps from CNC shop/factory in Germany- still digging in paper piled to find the name of the shop.
    ApriliaPista
    Mille Tech
    Have you checked Flyhammer?
    I know that Amauri has RSV4 yokes on his RSVR. Bolt-on swap. And the RSVR yokes also fit on the first gens. There are a couple of Falco's around with RSVR yokes and öhlins forks. So it's likely the RSV4 stuff will fit on the 1st gens.
    apriliaforum expert redratbike's Avatar
    Oct 2009
    with my modded collectors,Kent,UK
    Quote Originally Posted by Yzf600r View Post
    He wants adjustable headstock angle rather than fixed
    please get in touch if you would like a modded collector,adjustable lock-stops or quick release tank and seat pins
    apriliaforum Junkie CHAPlain's Avatar
    Jun 2013
    sw USA
    Quote Originally Posted by NitroArgi View Post
    I have seen Attack Performance triples on a Mille before. Call them again.
    Oct 2009
    Thing is our bikes are old now and the people that make stuff move on ,,chat to hemi426 over on rsvr.net he has a guy that makes custom bits maybe that’s the way forward
  1. $450 adjustable triple clamps
    By shmity1 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 06-03-2014, 01:50 PM
  2. Wtb:used adjustable triple clamps/xtrig/iceparts etc
    By weston22s in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-31-2009, 08:45 PM
  3. settings for adjustable triple clamps?
    By BC61 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-14-2009, 07:58 PM
  4. "NEW" Adjustable Triple clamps
    Last Post: 03-30-2009, 01:14 PM
  5. $400 adjustable triple clamps
    Last Post: 03-12-2009, 04:47 PM
