Results 1 to 9 of 9
Thread: 09 tuono runs rough under 4k rpms
    Oct 2017
    las vegas
    Just picked up this bike a month ago. Amazing machine, but after a few days of slower riding in tight twistie,s the low end is running rough. I have leo vince slip ons, no baffle. I live in Las Vegas where there are no good Aprilia mechanics. I read on here I need to unlock map 2 and -1 sprocket in front. When I called the only Aprilia dealer about unlocking map 2 they were not sure what I meant. Can I sent my ecu to someone AF1 or to Amauri. Love this bike but need to smooth out down low for real world riding. Thanks for any info guys.
    Sea Bass
    37 miles E. of ATX, TX USA.
    The Rotax V990RR motor you have will never run smoothly below about 3,700 rpm, hence the nature of a 60 degree V-Twin motors with high compression, primary imbalance (has balancer shafts but they cannot smooth the entire rpm range) and big camshaft lift and duration. We can unlock Map2 easily on a mail in service, swapping front sprocket is no harder on the Aprilia than any other motorcycle. My preferred gearing is 16:44, since the speedo pickup is NOT off the countershaft like Japanese bikes of the era you will not get speedo inaccuracy from changing final drive gearing.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Oct 2017
    las vegas
    thank you for info. sounds like changing out the rear sprocket is the only thing I should do. What is the purpose of unlocking map 2 then?
    Turns off oxygen sensor feedback to ecu, runs on base mapping appropriate for slip on pipes, improved throttle response. If you already have a 16T front just order a 44T rear in steel and you will be happy for many miles and lose no top speed but get to same top speed much quicker as bike has aerodynamically limited top speed in stock or lightly modified form.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Oct 2017
    las vegas
    I will follow your advice, thank you!
    Oct 2017
    las vegas
    Micah
    Thank you for giving me great advice on my 09 Tuono. So far I have put on 44 tooth in the rear and had you guys unlock map 2. Runs very good here at lower elevations but when I took my bike to Big Bear California at higher elevations it lost some power. Any ideas/ air box mods to increase air flow?
    Thx Brian
    Sep 2016
    montreal
    there is a restrictor plate right at the air inlet of the air box. that would help a bit. theres also an air box kit thats for sale right now in the parts if you want a bigger intake + velocity stacks
    Sep 2015
    Phoenix
    Power loss is naturally going to happen when you climb in elevation. Especially past 5k feet.
    Oct 2017
    las vegas
    thx guys! I will check out that restrictor plate 1st.
  1. Sporadically Running Rough @ Low RPM. Still.
    By Ozman2downs in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-07-2017, 01:23 AM
  2. Rough running under 4000 rpm and run perfect over
    By Hovalk in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-23-2015, 10:39 AM
  3. Running rough at 4k revs
    By TOMMYBOY in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-29-2014, 07:33 AM
  4. Replies: 2
    Last Post: 10-22-2012, 05:52 AM
  5. my tuono is running rough!!! any tips
    By stangbanger00 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 08-16-2009, 10:41 PM
