Results 1 to 2 of 2
Thread: SR50 Factory - starting problem when it's warm
    Oct 2012
    Czech republic
    Hello. I have a sr50 factory, 40,000km. There was a problem with the water pump, it started all right.
    First I took off the injector and replaced the seal under my head.
    Then problems with idling and starting began.
    Then I built the engine, a new water pump, a new cylinder seal (0.8mm), a new injection seal and head.
    Now, if it's cold, it starts well and goes well behind the gas.
    After warming up after a few minutes, I must hold the starter for a long time before grabbing. It does not go very fast, runs for 1-2 minutes at idle and goes out.
    The pressure of the air pump is 110-120 psi. Some idea? Thanks
    Jun 2013
    croatia
    on 40000km chec the cylinder compression piston rings and check the compression of the engine and the air compressor when hot
  1. Help with RSV4R Starting problems when warm
    By dstroman in forum 2010-2018 RSV4 - All Variants
    Last Post: 07-03-2014, 11:52 AM
  2. Help with RSV4R Starting problems when warm
    By dstroman in forum Aprilia Privateer / Club Racing
  3. HELP! 2009 SR50 Factory Running Issue When Warm
    By sfkirin in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-28-2014, 05:13 PM
  4. HELP! 2009 SR50 Factory starting problem.
    By kenji187 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-19-2014, 08:54 AM
  5. 02 RSVR, Starting problem when engine is warm
    By RSVRCorser in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 05-20-2009, 05:41 PM
