Results 1 to 3 of 3
Thread: 2009 Scarabeo 200- gear oil
    Dec 2017
    Mimai, Fl
    Just picked up a 2009 Scarabeo and I want to change the gear oil. Could really find anything on online specific to Scarabeo. Any suggestions?
    Aug 2008
    Winnipeg, Manitoba, Canada
    I'm assuming you mean the rear differential. A good synthetic multi-grade gear oil such as Amsoil 75-90w will do the trick. I believe 200cc is what the manual calls for. I put in a touch more since it likes to adhere to the sides of the container. Take it for a spin to warm it up before you drain it.
    Sp56
    Clearwater, Fl
    This is a no-brainer (and I don't say that to be flippant or insulting). Check out the forum sponsors web sight and under the Scarabeo 200 section they list very clearly the Factory Specified Gear Oil for that bike - AGIP Gear Oil Gear Synth 75W-90 1 Liter (AGGear7590):
    http://www.af1racing.com/store/Scrip...W%2D90+1+Liter
    I highly recommend spending some quality time on our hosts online store since they have many of the parts, breakdowns and recommended maintenance items for the US bikes from Aprilia, Moto Guzzi, Vespa, Piaggio, Norton, Ural, Zero, Genuine and EBR. They provide a wealth of information including what other bikes a particular part or maintenance item will be suitable for which is great when you need something fast and find that even though your nearest Aprilia Dealer does not have it that potentially a Vespa, Piaggio or even Moto Guzzi dealer might have a part that crosses over. You can also email them directly if you need direct expert advice plus they also answer the phone and will talk to you. You really have to work hard at it to have a bad experience dealing with AF1 and one can't really speak highly enough about their ethics as they set the standard that other dealers only wish they could come close too.
  1. 2009 Scarabeo 200 oil and filter change
    By Chindog in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 05-30-2016, 05:12 PM
  2. Help 2009 Scarabeo 200 fork oil? how much?
    By robz924 in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 05-12-2013, 11:20 PM
  3. Changing Hub Oil on 2009 Scarabeo 200
    By scarascoot in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 01-09-2012, 02:47 PM
  4. 2009 Scarabeo 200 (first oil change)
    By gti6cyl in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 10-26-2011, 11:27 AM
  5. Scarabeo 250 gear oil
    By MEPHISTO in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 03-01-2010, 12:48 PM
