Results 1 to 10 of 10
Thread: Strange noise from just below handlebars
    apriliaforum Member FactoryPete2016's Avatar
    Feb 2016
    Maui
    I'm hearing a strange noise from the top of my forks/handlebars. Not sure to it is. It happens when holding the front brake and pushing down on the front end compressing the forks. It sounds like it is coming from up top.Not sure how to describe it other than it sounds like someone cracking their knuckles
    I just had the tires replaced. I don't see how that could have made a difference but i'm stumped.
    apriliaforum Junkie Blackfin's Avatar
    Jul 2016
    Ontario, Canada
    Quote Originally Posted by FactoryPete2016 View Post
    I'd go over every fastener in the front; the wheel was off so the brake pads were out, the brake calipers removed, the pinch bolts loosened/removed, the axle removed etc. Go over everything.
    apriliaforum Member ZedRex1200's Avatar
    Sep 2017
    Calgary AB, Canada via Leicester UK
    Quote Originally Posted by Blackfin View Post
    Indeed!
    apriliaforum expert MishMashRSV4's Avatar
    Feb 2011
    Glendora, CA
    Remove tripleclamp, check bolts holding handlebar mounts to ensure they are secure
    nottingham
    I lnow it sounds daft but it isnt the floating disc noise? Jisy throwing it out there
    Jul 2017
    Northwest Indiana
    Quote Originally Posted by cheesemanpaul View Post
    This would be my guess.......
    Feb 2016
    Maui
    I thought that at first but it has never done that or sounded like that before.
    apriliaforum Junkie Darth Vader's Avatar
    Aug 2011
    Sydney, Australia
    +1
    it can be disc noise...
    Is it cracking or nocking noise ?
    Handlebar holders can make cracking noise... no rubber mounts on tuono...
    nottingham
    Steering head bearings may need adjusting? Depending on how many wheelies you pull etc. Just another guess.
    Not sure how old your bike is.
    Feb 2016
    Maui
    2016 factory
  1. Strange noise from rear diff
    By russttu in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-15-2009, 08:02 AM
  2. Strange Noise from forks
    By zoomdoof in forum SL1000 Falco Forum (all years)
    Last Post: 09-10-2009, 03:13 AM
  3. Strange noise from A500
    By pwroftwo in forum Aprilia and Piaggio 500cc
    Last Post: 05-28-2005, 11:39 PM
  4. strange noise from tail section?!
    By vtrandall in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-08-2004, 01:34 AM
  5. Strange noise from the Drive Shaft ?
    By Pauls 500 NYC in forum Aprilia and Piaggio 500cc
    Last Post: 12-18-2002, 11:13 PM
