Results 1 to 4 of 4
Thread: Fault 11 & 12
    apriliaforum Member PSUCJ's Avatar
    Mar 2004
    Lititz, PA
    Fault 11 & 12
    My 03 T died at home, will not start and is giving a fault 11 & 12. Both sensors test within range of OHMS. And the ohms on both change during cranking. I replaced both sensors a year ago during a troubleshooting session. The crank sensor was new, as was the stator, and the cam sensor was used. I still have the old cam sensor I could swap out. To make things worse the front right cam cover bolt for the front cylinder is stripped and frozen in place. Any ideas how to get it out? Is my ECU bad? She has over 80k miles on her and is beginning to get on my nerves. I noticed the cam sensor and crank sensor are exactly the same. I did remove a spark plug and I do have spark when cranking but the injectors do not squirt.
    Chris
    2003 Tuono
    apriliaforum expert THUNDR's Avatar
    Sioux Falls, SD
    Are the in-tank fuel lines good? There is a sticky thread on it at the top of the forum.
    2003 Tuono (In the garage still!)
    2010 Sachs Madass 125
    2011 Kawasaki Concours 1400
    2013 Tuono V4 Black (Most Addicting bike to ride so far!)
    Oct 2015
    South Yorkshire uk
    Is the fuel pump priming and pressurising the system? Sorry for asking what may seem obvious
    Mar 2004
    Lititz, PA
    Yes, the fuel pump is working and the lines are clear. I fixed it. It was the cam position sensor. I replaced the sensor, starter solenoid and the spark plugs and now it's working again. Thanks for your help. Happy Holidays!
    Chris
    2003 Tuono
  1. SR50 Ditech - ECU/Injector Diagnosis - ECU fault 11/12
    By nz.reidfamily in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 01-11-2017, 06:51 PM
  2. when do the v4 tuonos arrive state side? late 11 or 12?
    By zvez in forum Aprilia News and Product Discussion
    Last Post: 03-21-2011, 07:31 PM
  3. Barber Oct 11 and 12 NESBA
    By 5axis in forum Aprilia Owner Rides, Trackdays, Meetings, and Events
    Last Post: 10-06-2008, 07:50 PM
  4. EFI faults 11 and 12
    By raptor10 in forum SL1000 Falco Forum (all years)
    Last Post: 09-20-2008, 07:33 AM
  5. California Speedway 8/11 8/12
    By huskyrider in forum Aprilia Owner Rides, Trackdays, Meetings, and Events
    Last Post: 08-13-2006, 03:21 PM
