Results 1 to 15 of 16
Thread: Speed sensor
    apriliaforum expert ned's Avatar
    Jan 2015
    liverpool
    Speed sensor
    Hey fellas.
    I need a new speed sensor for my falco.
    Ive seen a new one for a dorsoduro which looks the same .
    Does anyone know if it will fit my falco.
    Jun 2009
    oldham uk and soon gibraltar
    Not sure but as the same back wheel will fit I put the oz from a Millie r in my dd it should work same disk spacing if not Millie ,capo,tuono will work
    Jan 2015
    liverpool
    Ive just bought it so we will find out soon enough
    Feb 2016
    Denmark
    Best of luck, mine is cracking where the cables enter the sensor, so it will be interesting to hear the result .
    Oct 2009
    Quote Originally Posted by ned View Post
    Keep us posted Ned
    Jan 2015
    liverpool
    Will do pal.
    Them asda vouchers never turned up ....
    Bastards...
    He he
    Jan 2015
    liverpool
    Great news fellas.
    The dorso speed sensor is virtually identical.
    Its better where the cable enters the sensor with a more robust moulding.
    The cable is about150mm longer which causes no problem.
    The white end plug is the same too.
    I gota new genuine part for 40 quid . Happy days
ID:	347677Click image for larger version.
    Jun 2015
    Sweden
    ah top notch stuff! Mine was acting up a bit weird before winter hit. Now i know what replacement to get!
    Oct 2009
    But does it work ????
    Jan 2015
    liverpool
    Quote Originally Posted by redratbike View Post
    Good question my friend.
    Ill let you know when it stops snowing.
    Weather here is propper shit .
    Cant see any reason why it shouldnt work as its almost identical.
    Aug 2013
    Europe
    You can put the bike on the rear stander to test speed sensor
    Jan 2015
    liverpool
    Yep good idea
    Jun 2009
    Yep good idea
    Go on out into the artic winter just so we can see if it works not that we need one till spring
    Feb 2016
    Denmark
    Lol yes yes yes
    Jan 2015
    liverpool
    Yes it works fine.
    Just a quick spin of the back wheel shows 2 mph
  1. RS250 Speed Sensor
    By ripready in forum RS250
    Last Post: 11-22-2005, 07:59 PM
  2. Speed Sensor
    By Little Merv in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-16-2004, 03:52 AM
  3. Speed Sensor Question
    By angrybob in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-24-2003, 12:43 AM
  4. looking for the right speed sensor wire
    By Dood in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-16-2003, 11:23 AM
  5. DiTech- Speed Sensor?
    By Aldo Steptoe in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 01-07-2003, 03:57 AM
