Results 1 to 3 of 3
Thread: SR50R Oil Pump test?
    May 2013
    Jersey Channel islands
    Smile SR50R Oil Pump test?
    Hi all,
    I want to check that my Piaggio oil pump is working, so my plan is to drain the petrol tank and refill with a oil and petrol mix, then remove the oil feed to the carburetor and check that the pump is working.
    My question is what would be the best oil to petrol ratio to put in the tank whilst I test the pump?
    Hope this makes sense : )
    cheers
    Spudy
    ontario
    sure but dont forget to remove the carb bowl drain screw and turn it over till premix fuel pours out/then you can start it up. when the oiler works aswell as premix at 40:1... it will get smokey
    May 2013
    Hi Sublunacy,
    thanks for the reply and info 40:1 it is
    cheers
    Spudy
  1. Replies: 21
    Last Post: 10-21-2015, 09:25 PM
  2. SR50R oil pump??
    By luke69 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 11-11-2007, 04:08 PM
  3. How to test 2T oil pump is working
    By GothicDraconian in forum RS125 Euro-archive
    Last Post: 05-08-2007, 07:15 AM
  4. How do u check if ure oil pump is working?????
    By priller1 in forum RS50 Technical
    Last Post: 06-19-2003, 12:27 AM
  5. How do u check if ure oil pump is working?????
    Last Post: 06-17-2003, 02:57 PM
