Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: 2017 TV4F damper not working?
    Dec 2009
    2017 TV4F Steering damper not working?
    Anyone else notice that there is barely any dampening difference from min to max on the ohlins units?
    I am asking the dealer check it, but the service writer said it only activates above 140mph.
    I tested another new unit sitting on the show floor, but it was the same as mine and even an RF that was sitting there was also similar.
    Is this normal...my zx10 had a pretty useless ohlins as well, but I have higher expectations for Aprilia.
    Anyone else notice this?
    Thanks in advance
    Patrick
    apriliaforum Junkie Blackfin's Avatar
    Jul 2016
    Ontario, Canada
    If you're talking about the steering damper then, as I recall, there was a big difference from max to min on mine.
    And tell your service writer you'd like to talk to someone else; clearly doesn't know what he's talking about.
    Dec 2009
    Yeah, the Steering damper...I figured it was probably has little or no oil in it. I have seen that before on Ducs out the crate
    apriliaforum prov-nov maximus7's Avatar
    Jul 2017
    SoCal
    Turning the bars from side to side while its sitting on the showroom floor is an invalid test; Its only going to work when in use & the front wheel gets jarred; thats how suspension works, it requires sudden heavy force to dampen the blow.
    Dec 2009
    Quote Originally Posted by maximus7 View Post
    I have an non electronic linear ohlins on my s1k and it's provides a lot more resistance at full slow vs full fast stationary.
    Finland
    Yes the ohlins damper on these bikes are really soft. Almost no difference in the settings. Inside there is a valve with holes. You can change this valve to a model without holes. After that the damper is good with a lot of adjustment from soft to stiff. It is kind of race spec for this damper. There are 2 different models. The valve with holes and without. I made this change at a ohlins mec, it was about 80 euro parts and work.
    Valve is wrong word, what i meant is a needle. Standard is needle with holes and you change that to the one without holes. After that it has more adjustability and is a lot stiffer in the stiff end.
    apriliaforum Member manic_grin's Avatar
    Mar 2017
    UK
    My Sachs just made a sad squelchy sound when I lifted the front and moved the bars. Swapped it out for an aftermarket one and it's much better.
    2013 Tuono APRC Yellow Crotch Banana with...
    Heated grips, Stompgrips, 15-44 sprockets, tail tidy, new steering damper, titanium spindle nuts, PIAA bulbs, USB ports, RAM mount, gel seat, RSV4 air filter, RSV4 tail unit, crash bungs and engine covers, shortened Akra, IRC auto blipper, Gabro ECU reflash
    Jul 2017
    Northwest Indiana
    Does anyone make a good aftermarket damper that fits our bikes? If so any info. would be great....
    apriliaforum Junkie johnnyjellybean's Avatar
    Sep 2017
    Laurentian mountains, Quebec
    Quote Originally Posted by CRFan1 View Post
    Yes ....... one that is not overly expensive.
    2013 Tuono V4
    2007 Harley Streetbob 120RWHP/120RWTQ
    Mar 2017
    UK
    https://www.ebay.co.uk/itm/Gold-Stee...O/321712641220
    You need a piece of 8mm nylon tubing, 10mm long as a bush as the hole in the middle clamp bit that screws under the dash has an 8mm hole and it's a 6mm bolt. Apart from that, it adjusts from completely locked up (not advisable to ride with it like that!) to floppy as a dead otter.
    Jul 2017
    Northwest Indiana
    Quote Originally Posted by manic_grin View Post
    Great info. thanks! Not 100% sure I trust the chinese steering dampers on my bikes though....the whole "locking up" bit scares me, hehehe
    Mar 2017
    UK
    Well don't tighten the screw that hard! You can lock up any steering damper with a needle valve.
    Jul 2017
    Northwest Indiana
    LOL...well of course....just have dreams of metal shaving floating in the oil and locking it up. Yeah I know, I need to get over it, lol.
    Jul 2017
    Northwest Indiana
    Just ordered one from ebay for 29 bucks....hope it fits on my 17 Tuono, lol.
    Mar 2017
    UK
    Fingers crossed the Chinese fella in flip flops has cleaned up the machining then! Or the Swedish fella in the Ohlins factors has done the same.
    With any part like this, the life of it will degrade over time. Next thing for my Crotch Banana is a look at the suspension and see if she needs a refresh to make her perkier and bouncier. The OEM Sachs unit had zero resistance and just squelched when I moved the bars!
  1. ATC Calibration not working with 15 front sprocket - 2017 RSV4 RR
    By fast_is_fun in forum 2010-2018 RSV4 - All Variants
    Last Post: 09-20-2017, 04:52 AM
  2. brake light not working
    By bernie in forum Pegaso 650 Cube and IE
    Last Post: 07-27-2003, 03:36 PM
  3. SR50 Sat And Not Working
    By garylythgoe in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-28-2003, 10:59 AM
  4. speedometer not working
    By joearena in forum Aprilia and Piaggio 500cc
    Last Post: 05-22-2003, 01:15 PM
  5. Mode select button not working
    By RC51rider in forum Aprilia and Piaggio 500cc
    Last Post: 02-18-2003, 04:46 PM
