Results 1 to 8 of 8
Thread: Voltage R/R output change before and after a ride
    Sep 2017
    St Louis MO
    Here's my ride report from yesterday:
    1) Begin, with battery fully charged (CTEK charger via pigtail I've installed).
    2) Motor starts on first attempt. Wait about 20 seconds, motor continues to run.
    3) Connect Battery Tender voltmeter to charging pigtail. Result: 13 V at idle, 12.7-12.8 at higher RPM
    4) Ride around for an hour or so then park the bike for a few hours and have pizza with a buddy and his wife at his house.
    5) Ride back home (about a 30 minute ride)
    6) Park bike in driveway and go inside. About 10 minutes later I decide that it might be interesting to check the voltage again, so I go back out, start the still pretty warm motor and get 13.9 - 14 V at idle and about 13.7-13.8 at higher RPMs.
    Does it make sense to you that a hot/warm motor would be about 1 V higher than a cold one?
    I guess the next step will be to take the voltmeter with me on my next ride and track the output more often during a ride.
    Sweden, Linköping
    Still the OEM R/R?
    If not, what have you replaced it with?
    Sep 2017
    St Louis MO
    Still the OEM R/R?
    I \haven't yet had a chance to remove the fairing to look, but the previous owners that I've spoken to (I don't have info from all of them) said that the brown connector and the R/R were still original. I haven no idea how accurate that is.
    My plan was to hopefully trouble-shoot the problem and get all the parts required then start to take things apart, but I may have to poke around a bit first then order the required stuff.
    Sweden, Linköping
    Poking around to know your bike is always good. If the brown connector never had the terminal crimps soldered, its a very potential trouble maker.
    Carthage, NC
    A warm connector may have a tighter tolerance than a cold one which could result in different readings.
    Ron
    MSgt USMC (Retired!)
    N2 CR
    WERA # 45
    IBA #38812
    RST Futura
    2007.5 Tuono
    apriliaforum prov-nov ChrisCrash's Avatar
    Oct 2013
    Cheshire, UK
    Ok Spin10k, I don't want to overdo this response, but there are many different reasons for what you are seeing. Please bear in mind that voltage readings can only be comparable between calibrated meters of the same meter (the option you are using). Just be aware that your meter might be reading high or low compared to others.
    Now, back to your question. I suggest that the CTEK battery charger is an intelligent charger with some care and consideration for the long-term state of your battery and so may have been gently trickle charging your battery and had not yet reached a fully charged (highest voltage PD). This can take days to achieve, depending upon the charger 'intelligence' and programming. The on-board charging system out of the alternator can be much more primitive with a high a.c. ripple content to the d.c. battery and is capable of putting much higher voltages out to the battery. This can 'over-charge' the battery and lead to potential problems. The brown connector can lead to reduced voltage to the battery and this can result in insufficient battery voltage to get a good charge. In your case, I would suggest that the bikes charging 'system' could be in a good state and putting a high voltage across the battery terminals, which the battery will eventually adopt (note (again), low voltage would probably mean a high charge current, and high voltage a low charge current - OK?).
    I would expect that your battery voltage will slowly drop, possible back to 13 Vish with no charge of any sort (good battery). Connecting the CTEK will charge at variable voltages, but possibly lower than the output of the on-board system and you will see the same thing on a similar ride in the future. When you see something dramatically different is the time to start thinking of problems.
    Alternative options available, some dependent upon what you have on your bike!
    As Deefred says, it's a good idea to find out what you have got as your 'system' and then you can know what you might expect.
    Mods: 2001 UK bike, metal fuel QD, FH008 R/R, replaced vac tubes, FPR mod, K&N air filter, air boot restrictor removed, two Hootax horns, digital voltmeter above tacho, replaced solenoid and feed/return wiring to battery and starter, NWS hugger.
    Aug 2006
    Santa Cruz, CA
    Very simple conclusion to your test results: Faulty RR unit.
    Yes, cleaned-up terminals might help.
    Yes, it's normal to achieve better warm charge volts after a 30 minute ride. It's still charging, and your battery surface charge is much higher than you started your day with. What ChrisCrash said somewhere in there.
    But it's charging wrong.
    Higher idle charge volts is opposite normal. A healthy setup will always produce higher voltage to a healthy battery at high RPMs. Period. And the regulator is working--it does allow 14 volts when it can. But the rectifier is shot, and cannot keep up with higher AC frequencies at elevated engine speed.
    Replace your RR unit and clean up your terminals before it strands you.
    Sweden, Linköping
    The OEM R/R has always charged higher at idle. Its designed like that. It may be failing any way but that is another thing.
    For piece of mind I would replace it with a mosfet unit.
  1. Evo race airbox before and after
    By xrfupa in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-13-2008, 12:10 AM
  2. before and after dyno graph
    By davel in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-21-2006, 07:57 PM
  3. Carlos' before and after Voltages from Wire Mod
    By Firebolter in forum SL1000 Falco Forum (all years)
    Last Post: 09-09-2005, 09:41 AM
  4. Gas Mileage (Before and After Break In)
    By ExtraJ in forum SL1000 Falco Forum (all years)
    Last Post: 08-02-2005, 08:20 PM
  5. Before and After - opinions please
    By MrSix in forum RS50 Technical
    Last Post: 05-15-2005, 05:37 PM
