Results 1 to 4 of 4
Thread: shiver with adjustable forks? Forks swap done?
    Feb 2017
    Hanoi, Vietnam
    Just realized that my Shiver forks have adjustments. They must be from some other aprilia?? One has dampening and other compression. Length is 765mm and they are showa brand. Not sure what is original shiver fork lenght?
    Nov 2016
    Lincoln
    Are they not Andreani cartridges?
    The V60 Tuono forks are a common swap, but are almost an inch shorter, and the brake caliper bolt pitch is slightly larger, so you'd need proper Brembo calipers off a Tuono as well. If your calipers say Aprilia, then I'd say they're the standard forks, perhaps poached from a different year bike so as to be able to accept the cartridges.
    If they are the standard fork legs, then they could probably stand to be raised in the clamps by a couple of lines to restore the geometry intended by design. That would give a neutral steering feel, instead of the aggressively corrective steering (you turn in, it tries to stand up) you get with the additional rake and trail caused by the forks being fitted flush like that.
    2009 Shiver (White) | UK
    Feb 2017
    Hanoi, Vietnam
    Yes, they do say aprilia.
    I also start to think they are that Andreani as haven't found any other that mach the top.
    Would this explain why bike feels so bad in cornering? it just don't want to corner at all!
    Nov 2016
    Lincoln
    When I moved my forks in the clamps, it made it much more enjoyable to ride in the corners - it would track a line perfectly and stay exactly where you left it. Before, with the fork tops flush with the clamps, it would wobble through a corner, constantly fighting itself and trying to stand up, requiring lots of corrective input. Tyres and gearing changes (or chain "stretch") affect geometry, too.
    The other thing that made a large difference was using thicker oil in the rebound leg, but with the cartridges in yours, you should be covered after a good setup.
    If you do a search, you should be able to come across plenty of opinion about fork height.
    E.g.: http://www.apriliaforum.com/forums/s...For-Forks-Sake!!
    It seems to me that the bike was always meant to have 2 lines showing above the clamp, but somehow lots have ended up flush. If you have lowered the rear in any way (shorter shock, lowering link etc.) then you will need more than 2 lines showing to restore the geometry - beware of clearance issues.
  1. DD 750 Showa forks swapped with 1200 Sachs forks
    By matic1982 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 05-30-2016, 06:00 PM
  2. Shiver 2012 with Marzocchi front fork
    By ashah13 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 10-02-2014, 10:39 AM
  3. need help with front brake/fork swap
    By zxmarc in forum RST1000 Futura (all years)
    Last Post: 06-21-2011, 06:13 PM
  4. new member !Adjustable front forks for shiver
    By Andy maws in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 03-10-2010, 05:25 PM
  5. Finally a ride with my "new" forks...
    By marc11 in forum RST1000 Futura (all years)
    Last Post: 03-08-2004, 11:20 PM
