Results 1 to 9 of 9
Thread: Rear Brake light switch
    apriliaforum expert Jeff U's Avatar
    Aug 2009
    Alexandria, Virginia
    My tail light is not lighting up when I press the rear brake pedal. The front brake lights up the tail light just fine so I'm guessing the rear switch or a loose connection.
    Brake switch looks like this:
    Anybody know where the white connector is located?
    I tried to follow the wire but have not yet found the connector.
    Nov 2011
    sth oz
    I have never had to play with one jeff but by the length of the wire I think it would be up around the passenger seat, there are the tail light plugs on the right side. If not, leftside under the rider seat.
    Feb 2009
    Have you unplugged and shorted it out yet to test?
    Aug 2009
    Not yet, I have not locate the connector to unplug
    apriliaforum Member mrk_d's Avatar
    Sep 2013
    Santa Barbara, CA
    On the Gen 1 it's behind the panel right below the rider's seat so I would imagine it's the same on the Gen 2. There wire isn't long enough for it to be far, in any case.
    I have a switch that I removed from my bike (I went to AP rearsets, which use a pressure switch instead). If you work out that the switch itself is the problem, you're welcome to have mine. The caveat is that I snipped the wires fairly close to the switch to install the new pressure switch, so I only have the switch itself and an inch or so of wire. Nonetheless, it is yours for the price of shipping if it would be useful to you -- PM me if you'd like it.
    Aug 2009
    Problem was the switch, replaced and all is well.
    The switch wire's plug connection is on the right side of the bike under a plastic boot just above the clutch case cover.
    Name:  Rear switch plug - 1.jpg
    Feb 2009
    Excellent Jeff...glad you got a fix.
    Thanks for reporting back.
    Jun 2006
    Columbus, GA
    Great!
    Just added to 1000cc FAQ Reference Thread - Common Issues Info
    2007 Tuono 1000R Factory
    2017 Z125 PRO
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Jan 2018
    los angeles
    bump.
    2017 rr model with aftermarket gp shift rearsets.
    i’ve had so many problems making this rearset work, and rear brake light switch is one of them.
    it doesnt mount to anything and is a 3 wire switch.
    can a simple 2 wire brake pressure switch be fitted for rear brake light function? or what is the 3rd wite for?
  1. rear brake light switch needed RSVR 04/05
    By blackduck in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-16-2006, 07:12 AM
  2. Rear Brake Light Switch nut size
    By dowzerr in forum RS250
    Last Post: 10-11-2005, 08:38 AM
  3. Argh Shit - Rear Brake Light Switch - Not In The mood!
    By VickersUK in forum RS50 Technical
    Last Post: 12-22-2004, 09:45 AM
  4. rear brake light switch
    By banjaxxed in forum SL1000 Falco Forum (all years)
    Last Post: 03-11-2004, 08:56 PM
  5. Rear Brake light switch broken
    By pbigoney in forum SL1000 Falco Forum (all years)
    Last Post: 10-14-2003, 01:58 AM
