Results 1 to 3 of 3
Thread: 17. Rr suspension settings
    apriliaforum expert punisher12b's Avatar
    Aug 2008
    Montgomery County MD
    Not looking for exact. But a good baseline for my husky 250lb self
    Sent from my LG-LS997 using Tapatalk
    2017 Tuono RR bone stock
    2003 zx6r track bike..
    E46 project
    lifted 6.0 powerstroke
    Prior
    2013 Diavel
    2001 Falco. Renegade Undertail CF, Derestricted, Mille Swinger, upgraded shock and big boy spring, wire mod, headlight relay, Intergrated Signals.
    1997 900RR
    1993 F2
    Quote Originally Posted by JCG View Post
    That guy behind you is huge, or was it Dr. Banner and you just cut him off!?
    Jul 2017
    Northwest Indiana
    Hmmm...I am about 225 without gear and I if I remember right, my settings ended up here:
    Forks:
    - Added a half turn preload
    - Compression I think 2 clicks (out) softer than stock
    - Rebound, 5 clicks from full hard
    Shock:
    - Added on full turn of preload
    - Compression in about 1/8 of a turn from stock (harder)
    - Rebound about 4 clicks in (harder) from stock setting.
    The key is getting the rebound set to remove the harshness. In the Chicago area our streets suck and in stock form the bike beat me to death. It rides great for me with these settings but everyone is different.
    apriliaforum Member clutchNthrottle's Avatar
    May 2017
    Harford Co, Maryland
    Quote Originally Posted by punisher12b View Post
    I go about 230lbs and have always set my bikes up with 30mm sag front and rear first, but couldn't get there on the stock forks so I'm thinkin I may need some beefier front springs. Then from there I've been content with the "race" settings from the manual:
    Front forks:
    Preload - all the way in gave me 35mm of sag
    Rebound - 4 clicks out from full in
    Compression - 8 clicks out from full in
    Rear shock:
    Preload 4 full turns in stiffer than stock gave me 30mm of sag
    Rebound 5 clicks out from full in (when laying on back looking up at shock)
    Compression - 1/2 a turn out from full in
    Also really want to pull the forks up another notch through the triples but haven't gotten around to it yet. Looks like I may need to disassemble parts of the fairing to get a torque wrench in there on some of those pinch bolts.
    2017 Tuono RR
  1. New suspension settings for '16 RSV4 RR
    By Unun in forum 2010-2018 RSV4 - All Variants
    Last Post: 06-04-2018, 07:25 PM
  2. Suspension settings for my '16 RSV4 RR for 150lb rider
    Last Post: 09-28-2016, 09:45 PM
  3. RSV Suspension Settings
    By jmarkey in forum 1000cc f.a.q
    Last Post: 06-25-2014, 05:19 AM
  4. Tuono - suspension settings for the street
    By scabbard7 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-24-2003, 04:05 PM
  5. Suspension settings/new rear Works Performance Shock
    By pnoud in forum SL1000 Falco Forum (all years)
    Last Post: 02-07-2003, 12:13 PM
