Results 1 to 15 of 28
Thread: Winter spruce up
    Jun 2016
    North Yorkshire, England.
    Winter spruce up
    Tuono Gen 1, mostly there but just needs finishing off.
    Apart from checking the usually annual stuff like swing arm and dog bone bearings and re grease,
    I've had the wheels painted in satin black, c/w new bearings and 90 inflation valves.
    Exhaust ceramic coated satin black. The rear header will also get a DEI wrap.
    Re sprayed the fork lowers; rubbed them down to find a thin top coat only courtesy of Showa.
    Now under coated, painted and lacquered. Since the photo I've also fitted some aircraft leading edge
    clear tape to the front of the lowers to hopefully prevent any more chipping.
    apriliaforum prov-nov mrk_d's Avatar
    Sep 2013
    Santa Barbara, CA
    That looks really nice, I really need to give my bike a solid stripdown and thorough cleaning! Curious to see how your bike looks with the nice black wheels and exhaust.
    Aug 2005
    Perth W/Australia
    Nice !
    Tuono Racing + KTM 990 Adventure =
    Aug 2010
    Chojnice POLAND
    Nice. I will do same thing with my suspension..
    Wysłane z mojego D2303 przy użyciu Tapatalka
    Jul 2009
    Nice. More pictures please!
    apriliaforum expert ned's Avatar
    Jan 2015
    liverpool
    Where did you get the ceramic coating done matey.
    I need this...
    Oct 2009
    Jun 2016
    Yep Camcoat, great people to deal with and first class product.
    Jun 2016
    Rear header wrapped in DEI and fitted.
    Collector fitted and also front wheel and forks.
    Jan 2015
    liverpool
    Bike looks great there fella.
    Have you got any other mods planned other than asthetics
    Aug 2005
    Perth W/Australia
    That stuff on the read header will make it rust. Sure you want to keep it on ??
    I have never really noticed the heat from it. The rear shock dosnt seem to suffer performance issues either.
    Jun 2016
    Quote Originally Posted by RossGuzzi View Post
    Won't rust with the ceramic coating on it; I've already run the rear header since last winter with the DEI wrap and when it came off for coating, the header was clean.
    As for the rear shock, I've got an Ohlins fitted and I run on the Yorkshire Dales back lanes mostly...the shock gets a good work out! Why add to the grief it gets when you can
    help it out.
    I've already fitted K&N, large air intake boot, removed intake grilles, modded collector (as per photo), straight thro' Giannelli can and FR200 chip.
    It's more than fast enough for me and acceleration with 15/43 is decent
    Oct 2009
    Quote Originally Posted by Stevex View Post
    must admit the Redratbike collector looks a lot better with the coating on
    Jun 2016
    HID low beam fitted.
    Ballast fits nicely without looking out of place.
    Wiring sorted in the light unit.
    High beam LEDs on their way.
    Aug 2005
    Perth W/Australia
    I had HID`s on my old Falco. I just could not get use to the time it takes for them to turn on going from high to low, low to high.
    I guess if you just use HID for low, and it is wired so it`s on all the time, it would be ok.
    I would like to go LED high beam. Would be interested in which brand you get. These guys do a good product. http://www.cyclopsadventuresports.co...ulb-_p_83.html
  1. Laying up for winter - advice pls...
    By Kevbird in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 11-26-2008, 04:09 PM
  2. First winter for my Di..And no problem starting up
    By SR50DI-TECH in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-10-2008, 10:42 PM
  3. Do you lay your Mille up for the winter (UK based question tbh!! )
    By RSV_Ecosse in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-13-2005, 07:35 PM
  4. Up for winter storage :-(
    By mysubaruimp in forum General Motorcycle Talk
    Last Post: 11-22-2004, 09:27 AM
  5. winter fix up
    By chaseme in forum RS50 Technical
    Last Post: 10-21-2004, 04:54 AM
