Results 1 to 15 of 28
Thread: Hard to find neutral
    apriliaforum Member rsvrick's Avatar
    LI, NY
    My new (to me) '12 Tuono has me doing a tap dance at stop lights trying to find neutral. 1st-2nd-1st-2nd ....you know the drill. Is this a common idiosyncrasy with this bike or is it a simple fix like adjusting the clutch cable or adjusting the idle? Am I the only one? I know the PO had to replace the clutch cable, which I thought was a little weird since the bike only has 5k miles, but I don't know exactly why. Is there an inherent problem with the clutch on the early Tuonos?
    '12 Tuono V4 APRC
    '03 Ducati ST4S
    apriliaforum expert antarius's Avatar
    Jul 2017
    Bay Area, California
    Common!
    Fort Collins Colorado
    Pop it in to nutral before coming to a complete stop.
    Apr 2016
    OC, CA
    Normal. Drove me crazy in the beginning but you get used to it pretty quickly.
    apriliaforum Junkie johnnyjellybean's Avatar
    Sep 2017
    Laurentian mountains, Quebec
    Inch the bike forward as you come up from 1st gear. Once you get the feel for it, you'll find it easy
    2013 Tuono V4
    2007 Harley Streetbob 120RWHP/120RWTQ
    apriliaforum expert VFR4Lee's Avatar
    Sep 2008
    Sitting on a park bench. Eyeing little girls with bad intent. Channeling Jethro Tull.
    My '07 had this issue, so does the '03.
    You might think they would have solved it by '12.
    My Tuono suits me to a "T".
    Thunder!
    Feb 2016
    Northamptonshire, UK
    I adjusted my clutch and it went from almost impossible to just a little tricky if it was really hot
    apriliaforum Junkie Darth Vader's Avatar
    Aug 2011
    Sydney, Australia
    It is true that finding neutral can be a nightmere but some aftermarket levers are very bad and will not help at all... and worn guiding bush inside the clutch cover is not helping either... tuono already has a clutch pulling pin with less teeth comparing to first RSV4, to prevent that problem...When you operating clutch lever and if you can feel a small step approx on the half way of lever traveling, than guide bush is worn for sure and clutch is not separating enough....
    Jan 2007
    Hammond, Indiana - USA
    Good info Darth, on the bush.
    Never had a problem finding neutral on my 2016 Tuono, all stock.
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
    apriliaforum expert oldbluechair09's Avatar
    Nov 2013
    MA
    My 2013 is difficult to find neutral. Seems to be a common problem. I shift into neutral just before coming to a stop. I find that a little bit easier. If I don't get the chance and I'm already at a stop I slip the clutch and move forward just a touch and click it on then. You will get used to it.
    2013 Aprilia Tuono V4R APRC Matte Black
    2013 Triumph Daytona 675R
    Sep 2017
    Quote Originally Posted by oldbluechair09 View Post
    ^^ This ^^
    2013 Tuono V4
    Nov 2017
    Florida
    My '17 is impossible to find. You CANNOT get into neutral going from 1st to neutral. The only way to do it is to go from 2nd to Neutral.
    This cant be right...
    Granted, this is the second 17 and its exactly the same on both. Hrm. lol.
    Oct 2013
    San Diego, CA
    Interestingly my '17 Tuono Factory is super easy to find neutral. My '13 RSV4 has never been very easy but I learned to live with it without issue, so I was shocked when I can easily click the new Tuono into N at a stop!
    Jul 2017
    Northwest Indiana
    Just a curious question for those that are having nuetral issues....what brand oil are you using?
    apriliaforum expert ghedunk's Avatar
    Nov 2005
    NJ
    My 04 and the 2012 both have no problems finding neutral . Click both of them in neutral at every red light . I don't like the clunk going into gear . But its wet clutch so you got to live with it .
    04 Tuono
    09 Husqvarna SM610IE
    84 R100RS
    83 R100RT
    08 Concours14
    12 Tuono V4 a-PRC
  1. Installed Barnett Clutch, now hard to find Neutral
    By davesmyth in forum RST1000 Futura (all years)
    Last Post: 03-13-2013, 05:39 PM
  2. hard to find neutral/clutch drag
    By kboe in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-29-2008, 12:47 PM
  3. Clutch and hard to find neutral
    By Millenist in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 09-28-2007, 12:29 AM
  4. Hard to find neutral
    By Crabman in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 10-16-2005, 09:47 PM
