Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 65
Thread: Caponord 1200 Rally - Front Cylinder Timing Gear
    apriliaforum Member andydj31's Avatar
    Jun 2005
    near Noale!!
    Quote Originally Posted by jmsarat View Post
    What is causing this problem? bad quality or bad design? The part number didn't change so replacing the timing gear could be a short term solution. What is your experience after the recall?
    A bad processing by the supplier.
    P.S. sorry for my bad English!!
    Aprilia Caponord 1200 Rosso Formula
    Aprilia Rst Futura '02
    Aprilia Caponord RR '04 "Gundam" o "Biscottone".
    Aprilia Pegaso Cube 650 '01 "La piccola".
    Dec 2014
    United States
    Hey Bosnz
    Do you have any info on the recall on this issue? I'm close to pulling the trigger on a Rally and wanted to ask the dealer about the recall
    Thanks!
    Nov 2017
    Uruguay
    I have both the old and new part, and the printed numbers are different, +1 in front +2 in back, I could upload pictures, so its not the same part.
    (I purchased two sets of gear+axle, but only replaced the front, will replace the back in 2/3k kms)
    Also the copper bushing looks different, there is a empty space in the new part, while in the old one is continous... looks they fixed the problem.
    Also the front cylinder is very very quiet after the change and 1000kms.
    apriliaforum Junkie Darth Vader's Avatar
    Aug 2011
    Sydney, Australia
    i did change timing gears on several bikes... why removing or loosig a handlebar ??? No need for that...
    BTW on shiver and dorso 750 it is possible to pull gear out of the head without of removing the chain from the bike... that makes job much easier... no need to remove clutch cover, only ignition cover to place timing tool on the rotor...
    Nov 2017
    Uruguay
    if you see la list of 20 ítems, and you choose the one that is far, far away simplier than the rest and you question that... my god
    you need to loose or remove the handlebar to remove the gas tank...
    also, chain in the bikes you mentioned are one in one side, and the other in the another side... you cant remove both cam chains from the same side...
    are you sure you have knoledge on what you are talking about or just pure BS?
    Aug 2011
    Sydney, Australia
    Quote Originally Posted by aleib View Post
    Sorry mate... Pure BS mate ... pure BS.... but from you...
    trying to help others not to do wrong and unnecessary things...
    You do not need to lose handlebar to remove the tank.... and there are others things written wrongly... anyway...To remove tank without of loosing handlebar you have to unplug fuel hose and fuel pump wiring, fuel level sender on the front, two breather hoses on both front side, than rise the rear end of the fuel tank and than slide it back...piece of cake....
    Both V2 configuration, 750 and 1200 are basically the same ...
    Front cylinder has a chain on the right hand side of the engine.. clutch side...
    Rear cylinder has a chain on the left hand side... ignition side...
    In both cases, if you want to do the job properly you have to recheck and readjust timing after changing timing gear... that is a MUST....
    for that job you need to attach timing tool instead of the magnet - rotor... it is possible to do that without of the tool with a bit of imagination, but timming must be checked and readjusted...sometimes nuts on the camshafts has to be loosen and gears on the camshafts has to be readjusted...
    Another info..
    If you changing timing gear on the rear cylinder, frame is on the way of the special bolt... It is enough to remove engine mounting bolts and jack engine up for approx 5-7 mm ... than is possible to remove the bolt...
    Dec 2011
    Arizona
    Quote Originally Posted by Darth Vader View Post
    Another info..
    Also note that the rear timing chain tensioner interferes with the frame. Took two people to get that thing reassembled.
    Sent from my SM-G900P using Tapatalk
    Aug 2011
    Sydney, Australia
    Quote Originally Posted by dograt View Post
    Yes it is a bit of hasle... it is easier if you remove big bolt - spring cap on the end firstly and remove spring from inside.... with swivel socket is much easier...During assembling I usually change bolts for allen keys, found that helpfull...and than spring and than cap.. nerve wrecking sometimes... but it is worth of not removing the engine...
    Feb 2013
    France
    Hi Darth,
    I removed several times the fuel tank but not completely as I don't know how to disconnect the fuel pipe from the pump. Do you know how to disconnect the pipe?
    Following your recommendation, I ordered the special tool, both timing gears with washers and gaskets. Thank you for sharing your experience. I'll report how complex or difficult it is.
    Jean-Marc
    Nov 2017
    Uruguay
    Some pics from the front job (will do the back in 1000kms)
    Bosch IDH182 could not loose it:
    wáter pump out
    cant get the gear out wihtout removing the chain:
    Nov 2017
    Uruguay
    cluth off, only the primary gear was left to remove the cain.
    Nov 2017
    Uruguay
    The soud of the gear removed in post #1 made this sound:
  13. #28
    Mar 2017
    British Columbia
    i noted the intermediate gear for the 750 was the same part number as for the 1200. One Theory could be the extra torque is chewing these bearing surfaces up in the bigger motors, but some 750's have been failing too. Best theory is bad bearing material and improper tolerances from chinese bearing manufacturer. Still no recall from the factory though....shameful.
  14. #29
    Mar 2017
    British Columbia
    [QUOTE=aleib;4360371]I have both the old and new part, and the printed numbers are different, +1 in front +2 in back, I could upload pictures, so its not the same part.
    It sounds like the old copper (I'm sure you mean brass) bushing without a groove to line up with an oil supply galley would be a major admission of incompetent engineering. Also noted in one of your pics looks like an oil galley in the casting not completely deburred prior to final assembly.
    Ciao!
  15. #30
    Nov 2017
    Uruguay
    just changed the back cylinder gear too... the engine is very quite now.. a lot of work... no need to move the engine in place, just loose the engine support and thats all.
    The problem was when we confirmed both parts, front and back are DIFFERENT different serial numbers....
    Thats probably (?) the reason why front cylinder fails first!
    I replaced both with new ones with the same part number....
    Whats going on with Aprilia?
  1. lost front cylinder fire time to time
    By Resurrected SXV in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-14-2015, 06:54 AM
  2. Caponord 1200 Rally MY 2015
    By Brucaliffo in forum ETV1000 CapoNord (2001-2007)
    Last Post: 01-25-2015, 01:32 AM
  3. Aprilia Caponord 1200 Rally - official video
    By RS4EVER in forum 2014-2017 Caponord 1200
    Last Post: 11-23-2014, 09:56 PM
  4. Aftermarket vendors - BMWOA National rally - Aprilia Caponord 1200
    By Bryannagirl in forum 2014-2017 Caponord 1200
    Last Post: 07-15-2014, 05:58 PM
  5. [Caponord 1200] FS: left and right front turn signal lights with bulbs
    By urbandaddy in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 06-21-2014, 11:05 AM
