Results 1 to 14 of 14
Thread: 1200 Rally radiator guard.
    Nov 2017
    Ulverston, Cumbria
    I'm trying to locate a radiator guard for my newly acquired 1200 rally but have been informed that Evotech have stopped making them. All others I've seen advertised are for the standard and TP models and won't fit the rally!
    Am I missing something here, does anyone know of an alternative make? Any suggestions would be appreciated,
    Many thanks,
    Nev.
    May 2017
    Quebec
    I bought the R&G and I can confirm to you that it fit the Rally version: http://www.rg-racing.com/browsebike/Aprilia/Caponord_1200/2014/RAD0153BK/#prettyPhoto
    Nov 2017
    Ulverston, Cumbria
    Thanks for your response, does the oil cooler part of the R&G guard fit behind the original oil cooler guard on the Rally version in effect having two oil cooler guards?
    Sep 2013
    Shropshire UK
    The rad on the Rally is not the same as the TP rad. The 'Rally rad' (sorry) is curved presumably to allow clearance for the larger front wheel. The TP R&G guard may well fit but make sure there is still clearance on full fork compression.
    Nov 2017
    Ulverston, Cumbria
    Thanks for the advice guys, I'd really like to find an Evotech rad guard for my 1200 rally so if anyone has a good
    Used one surplus to requirements I'd be happy to take it off your hands!
    Sep 2017
    Far Eastern Pacific
    Andrew Cox, owner of radiator guard maker Cox Racing in Oregon USA, just wrote me to say he can produce them for the Caponord 1200 Rally if he will have ten buyers.
    I've used them on the RSV1000 and Tuono Racing, absolutely top notch stuff with a factory race bike level of fabrication. He did the Tuono guards for me using titanium wire screening!
    Sep 2017
    Far Eastern Pacific
    This links to an example of Cox's radiator guards for the Tuono V4. Note that one of the available finishes is "titanium", but he also can do them with an actual titanium screening for an extra charge.
    http://www.coxracingroup.com/http-ww...&category=6847
    apriliaforum Member Falcoholic's Avatar
    Mar 2007
    Scotland
    I went with this one -R-G-Racing-Stainless-Steel-Radiator-Oil-Cooler-Guard
    {EDIT} Sorry, Rally you said.
    The Delicate Sound of Thunder
    Nov 2017
    Ulverston, Cumbria
    Thanks for the suggestions, I'm still after a rally specific rad guard preferably sourced from within Europe, the Evotech product was perfect for the job but they've apparently stopped making them (lack of demand maybe?)
    May 2017
    Quebec
    Quote Originally Posted by Caponev View Post
    I've seen no difference...anyway, the Capo is naturally hot and burn oil
    May 2017
    Quebec
    Quote Originally Posted by RSTman View Post
    It does fit well and it is a 15 minute and very simple installation.
    Nov 2017
    Ulverston, Cumbria
    Thanks for the reassurance 2brnut2b, it sounds like the R&G guard will do the job just fine, I'll get one ordered today!
    Mar 2017
    British Columbia
    R&G guard does fit the Rally but.....! There are wires at the top of the radiator that require additional protection from the razor sharp edge of the R&G unit. I filed the edges and slit a short length of 1/4" fuel line over the wires where they will rub. An ounce of prevention is worth several pounds of cure..
    Nov 2017
    Ulverston, Cumbria
    Thanks for the warning Mike, I will bear that in mind when installing the guard
  1. [Dorso] Evotech radiator guard Dorosoduro 1200
    By nerald in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 08-21-2013, 10:34 AM
  2. [Dorso] Dorso 1200 Evotech Performance Radiator Guards.
    Last Post: 04-22-2013, 09:40 AM
  3. CF radiator guards
    By Kid Thunder in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 07-20-2004, 01:15 AM
  4. radiator guards
    By venturaII in forum SL1000 Falco Forum (all years)
    Last Post: 10-03-2003, 12:05 PM
  5. Cox Racing Group Radiator Guard?
    By Ted in Evanston in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-20-2003, 09:05 PM
