Results 1 to 5 of 5
Thread: Aprilia SR 50 R
    Nov 2017
    Scotland
    Aprilia SR 50 R
    Hello, I am new to the forum and sorry if I am posting this in the wrong section. I own a 2005 plate Aprilia Sr 50cc R model and I have a problem with it which I cannot figure out. Basically, the bike has had problems in the past but nothing like this before, it can get to about 5mph then will cut out and die right down until it switches off, but when I unplug the cable that powers the headlights, the bike can reach up to 35mph then will cut out and jump about still. I have tried pretty much everything I can think of including cleaning the carb, changing the spark plug, and charging the battery fully but nothing seams to work, hopeing someone can help! Thank you I should also add that the bike runs fine while idle with the headlight block cable unplugged but as soon as I plug it back in the bike al,last immediately cuts out
    ontario
    i think the stator coil could use a test. check if it has any leaks to ground.
    --- diploma for engine repair in 2012 --- powder coat painting --- porting and polishing/ceramic ---
    --- custom parts and machining ---
    derbi bullet 2006 - piaggio AC - malossi torque driver half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter - TTO tempurature gauge
    complete wtp volta bmx 2012 - sanko seamless japanese cromoly heat treated and blueprinted frame - 21lbs
    1992 lt250r suzuki quadracer - maier plastics -chromed shearer pipe - chromed works suspension - 220lbs
    previous vehicles - subaru legacy turbo 1991 - mazda mx6 turbo 1990.
    tamiya fighting buggy and sand scorcher
    Nov 2017
    Scotland
    Cheers for the reply, looking at the stator coil now but some idiot has stripped the screws
    ontario
    sounds like its getting some power but not full strength i guess right? so yeah try a small ground leak at the stator or maybe its the rectifier in the cdi box i think. perhaps one of the 3 hot wires from the stator setup is not powering up or the rectifier is just faulty on one or more of the 3 hotwires from the stator.
    im not sure but its the only route that comes to mind.
    Nov 2017
    Scotland
    Hello again, been having a proper look at my bike and was playing around with a few things, noticed that when my battery is completely unplugged from the bike, the kick start will work perfectly so I'm beginning to think now that the stator coil is working fine, I will also add that the bike will pretty much not run at all when i plug in the white headlight block in. Any more suggestions will be a huge help thanks!
  1. scootnfast how fast should a aprilia sr 50 go
    By ggs34 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-17-2005, 10:22 AM
  2. 1996 aprilia sr 50 lc
    By dysan in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-21-2005, 12:50 AM
  3. aprilia SR 50 lc 2003 model
    By chriss in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 10-30-2004, 10:53 AM
  4. Aprilia SR 50 MY 2004
    By Nuclear in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-05-2004, 09:12 PM
  5. Aprilia SR 50 Ditech help please !!
    By vendetta in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-15-2003, 06:13 AM
