Results 1 to 4 of 4
Thread: Is there a comfortable aftermarket seat for a 2016 Dorsoduro 750?
    Jun 2017
    Cape Coral, FL
    I've searched pretty extensively today on the forums and basically come up with not much of anything? Early variants say get a 1200 seat, rework your current seat, etc. Doesn't anyone make an aftermarket seat that is way better than stock? I mean, the stock seat I get about 30 min before my ass is killing me...lol Basically it's the most detracting thing about the bike and I can find little to nothing as a decent replacement. :-(
    Input please! :-)
    2106 Dorsoduro ABS 750 / White
    ~ no mods yet...but they're comin...
    Feb 2012
    Sierra Nevadas
    Quote Originally Posted by PXM2513 View Post
    Input please! :-)
    There are companies that will re-work the stock seat, making it much better. Renazco is one I have heard is good. Maybe Moto.K, Saddleman, or other custom saddle makers too. As far as I know, there isn't a ready made seat you can just buy. They all want your original seat pan to work with, and charge $300-$400.
    Of the seats made by Aprilia, the 1200 seat is the best/thickest. This means it will raise the seat height a little bit. I can go twice as long before my butt gets tired, which is longer than a tank of fuel lasts. After a refueling break, I'm good for another hour. After 3 tanks I get a little sore. I think later model 750 bikes came with this same seat as stock, so if you go this route make sure you know what you are getting. They look slightly different, so you should be able to tell by looking at pictures. They can be had for $75 used.
    The Aprilia gel seat is the best looking seat, but only a small improvement over the stock 750 seat. These are about $120 new.
    If you want a genuine all day seat, the best thing to do is buy another stock 750 seat from eBay and send it off to have it customized. If you can find a local saddle maker, it's really not rocket science. Have the guy cut a circle out where you butt sits. replace that area with dense memory foam. take the circle that was removed and cut it in half. put those halves at the seat edges to make the spot you sit wider. Now round the edges where the backs of you thighs hit. This is what the long range BMW riders do.
    apriliaforum expert Satanic's Avatar
    Oct 2017
    UK
    Moto-Skiveez Adventure shorts extend seat time by 15 - 20 minutes. Fabric breathability in hot weather is impressive.
    Aug 2015
    Gilbert, Arizona (USA)
    My Renazco Racing seat is definitely more comfortable than the stock or Aprilia gel seat. Glad I was able to get a used one in good condition. Those things are expensive!
  1. Aftermarket seat for a 00 Mille
    By lieb1890 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-12-2005, 01:37 PM
  2. Aftermarket Seats for the RSV?
    By Mille_Drew in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 12-01-2004, 11:39 PM
  3. aftermarket seats for futura
    By dshafer in forum RST1000 Futura (all years)
    Last Post: 11-07-2004, 04:28 PM
  4. A good aftermarket Seat for the Capo?
    By erikthered in forum ETV1000 CapoNord (2001-2007)
    Last Post: 10-20-2003, 01:29 PM
  5. aftermarket seats for my rst1000
    By speed64 in forum RST1000 Futura (all years)
    Last Post: 05-27-2003, 09:53 PM
