Results 1 to 4 of 4
Thread: Possible electric problem
    Jul 2016
    Uk
    I noticed while riding at night the headlight on my mojito 50 will dim then brighten up every now and then also while accelerating the fuel gauge drops down to red then settles again has anyone had anything similar happen or know if it could be linked
    ontario
    is the dimming just close to the idle rpm or?
    the fuel gauge could do that if it is not used alot. but try some searching here on fuel gauges.
    Jul 2016
    Uk
    Dimming is at different revs can be when hitting full speed with throttle wide open I know it dims on idle but it's only recently started doing it while riding not sure why fuel gauge is doing that but bike is ridden everyday
    ontario
    i have seen alot of people with bad fuel gauges / i think they just replace them. if you search some i think thats what you will find.
    im not sure about dimming lights exactly. not alot of parts to bypass and check / like the switch... the scoots are wired pretty good. everything you want is under the dash i think.
  1. Throttle chopping in 1st gear (possible electrical problem)
    By mtb_prodigy in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 04-10-2017, 10:34 PM
  2. Plz help Electric problem
    By rs50adzs in forum RS50 Technical
    Last Post: 06-28-2003, 12:05 PM
  3. electric problems
    By bonanza 488t in forum RST1000 Futura (all years)
    Last Post: 03-14-2003, 07:12 PM
  4. Can you help with electrical problem on '95 Peg?
    By microbike in forum Pegaso 650 Cube and IE
    Last Post: 04-04-2002, 04:23 PM
