Results 1 to 14 of 14
Thread: Rear sprocket carrier hub.
    apriliaforum expert FTM's Avatar
    Aug 2005
    Portsmouth Uk
    Mines fecked and I need a new or used one in gold please. Plenty of silver ones available new, but gold is discontinued. There must be one out there somewhere.
    If not then it's either try and get a silver one anodized gold or is it maybe possible to machine the old hub and fit a larger bearing?
    FUCK THE MAGS
    Never live the same day twice. (My wife nearly pissed her self laughing when she read my signature line, because she reckons she has never met anyone in the whole of her life who hates change more than me) She does have a point .
    Jun 2016
    North Yorkshire, England.
    How bad is it? Looks like the bearing outer race has been spinning in the hub?
    Is it worth looking at using a Loctite bearing retainer, depending on your tolerances?
    Otherwise I'm sure an engineering shop could machine the hub to take an insert, then machine the insert to take an original bearing.
    All down to cost I guess.
    Sep 2009
    I know you're after a gold one, but I have a very good condition silver one for 25 including delivery if you go down the route of getting it anodised.
    Aug 2005
    Portsmouth Uk
    Thanks Tash I'll bear that in mind if I can't get a gold one.
    Stevex I think too much alloy was removed for Loctite but machining may be an answer, I'll have to ask around locally.
    FUCK THE MAGS
    Aug 2005
    Portsmouth Uk
    Tash do you know if the hub is silver anodised or just the natural aluminium finish? I think I've read before that it's hard to anodise over previously anodised surfaces.
    FUCK THE MAGS
    Sep 2009
    Certain it's just natural mate, I will check tomorrow
    Sep 2009
    Hi mate, it's just a natural finish
    Aug 2005
    Portsmouth Uk
    Tash that sounds good. I'll PM you.
    FUCK THE MAGS
    Feb 2009
    It's a pain in the arse re-anodising ali parts like that mate.
    Usually, the part is acid etched to remove the existing, then re coated.
    Bearing fit is never the same.
    I had some forks done many years back, and it was impossible to get a perfect seal fit.
    Was told that the acid etch takes off a bit of the meat?
    Oct 2009
    Quote Originally Posted by FTM View Post
    Griff can get it re-anodised he had my forks redone from black to gold...he has a guy he trusts
    Aug 2005
    Portsmouth Uk
    That's interesting. There's a realy good place near me that gets good recommendations. They will mask off areas so bearings aren't affected for a few dollars more.
    FUCK THE MAGS
    Where did you get a gold one anyway? I've never seen but one part number for the carrier across all models from 98 Mille through gen 2 and the latest V4's. SP, Nera, Racing, etc. All the same part number.
    Aug 2005
    Portsmouth Uk
    2002 Tuono R Limited, part number AP8125900. Number 11 here https://www.ultimateparts.net/aprili...o-2013&i=18713, discontinued part, non available from any Aprilia dealers. It looks like Aprilia sold off their remaining stock to clear shelves some time ago. Someone somewhere must have bought them all up at 10 each!!!!!!!!
    FUCK THE MAGS
    Curious. Never been up close to one of those.
    I like the wheels.
  1. 2002 Tuono Rear Sprocket Carrier / Hub wanted.
    By FTM in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 11-27-2017, 02:50 PM
  2. Rear sprocket carrier drive pin nut size?
    By BMEPdoc in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-15-2012, 02:05 PM
  3. Oz Rear Sprocket Carrier loose?
    By TTTuono in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 10-22-2011, 12:56 PM
  4. Rear sprocket carrier question
    By Chris_Mag in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 12-17-2008, 06:11 PM
  5. rear sprocket carrier loose!!!!
    By tmurray2626 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-03-2005, 05:31 AM
