Results 1 to 15 of 29
Thread: Changing exhaust
    Nov 2017
    UK County Durham
    Changing exhaust
    Hi Just been watching a video on GPR exhaust site they fit one of the cans and simply remove/disconect the exhaust valve cables and mechanism Has anyone done this and if so does the bike run OK without any warning lights coming on.Cheers Steve
    May 2017
    Quebec
    I think you will need the Healtech exhaust servo eliminator to avoid the warning light...
    Jul 2017
    Yorkshire Coast
    Yes, the Healtech plugs into the wiring socket of the servo motor that you remove when you remove the servo itself and the cables leading to the exhaust valve. Basically it cons the bikes 'brain' into thinking the servo is still there. Its pretty straightforward to fit and they cost about £40.
    40 odd powered two wheelers over 40 odd years. Currently in the garage are a 2016 Tuono V1100RR and a '79 Honda CB550F
    Nov 2017
    UK County Durham
    Spot Thanks Guy,s
    apriliaforum Member andydj31's Avatar
    Jun 2005
    near Noale!!
    Attention! You must re-mapping if use Gpr cans. You loose about 20 hp with db killer. Search for the graphic that I've posted about a Dyno launch here on the forum.
    Look here: http://www.apriliaforum.com/forums/s...-exhaust/page5 and here: http://www.apriliaforum.com/forums/s...&highlight=gpr
    P.S. sorry for my bad English!!
    Aprilia Caponord 1200 Rosso Formula
    Aprilia Rst Futura '02
    Aprilia Caponord RR '04 "Gundam" o "Biscottone".
    Aprilia Pegaso Cube 650 '01 "La piccola".
    WV... Northern Panhandle
    When I decided to install an SC-Project carbon oval, I removed the exhaust servo motor and exhaust all in one piece. I kept everything together in case I wanted to reinstall later.
    So....with the SC-Project can(unplugged), no mapping change and the ESE installed, I only catch a red light randomly if I do a start up in chillier than normal temps. I will go out though after a few minutes and a restart. So far, so good after 33,000 miles. (53108km).
    02 aprilia Futura
    15 aprilia Caponord 1200
    Nov 2017
    Yarm, UK
    Hi All. I've just fitted a GPR exhaust to my Caponord. I followed their video instructions as well and hoped that the warning light would disappear after a few rides. However, it didn't so I resorted to a Healtech. No warning light since this was fitted. No baffles fitted and it sounds fantastic. Recommended. Best regards, Richard.
    Mar 2015
    S.S. de los Reyes
    Hello
    I have a gpr for sale with your ESE in ebay. https://www.ebay.es/itm/152795888444...84.m1555.l2649
    One friend have an Arrow that sells me.
    Nov 2017
    UK County Durham
    Hey Diegole thanks for that but Im after the carbon one
    Jun 2005
    near Noale!!
    This is the graphic with Arrow, resonator and filter DNA stage 2. Blu line original map, red line something better.
    apriliaforum Junkie Chris Courtenay's Avatar
    Jul 2012
    auckland new zealand
    I have gpr carbon look pipe with baffle out(not sure why anyone would leave it in let alone dyno it in lol) ,dna stage 2 air filter,cat removed and healtech ese,really livens up the bike and souns great!
    Owned 2003 Mille 2006 Tuono 2013 Tuono 2013 Caponord
    Apr 2013
    Poland
    I'm about to install SC Project and Healtech ESE (ordered today). Do I need to make engine remap?
    apriliaforum prov-nov DiAbLeRo's Avatar
    Dec 2015
    Croatia
    Please share your experience with this setup, I'm considering the same myself.
    Tnx
    Sent from my MI 5 using Tapatalk
    Jul 2016
    Montréal, Canada
    I have GPR, ESE, DNA stage 1 (normal) air filter, Rapid bike easy fuel module. The whole thing looks great, pulls hard and sounds amazing. And with the help of the fuel module the throttle response is much smoother.
    2015 Caponord White TP
    Heated grips, Gel seat, Givi Screen, Aprilia Top Box, GPR Exhaust, ESE Healtech, DNA Stage 1 Filter, RapidBike Easy Module, RAM Phone mount
    Oct 2013
    Santa Cruz Ca
    Can I do this farkle or modification without red warning lights and a decrease in power. Im hoping for an increase in power. FYI I live in Ca US with unusual restrictions in exhaust modifications. I happened to see a stock muffler with major disfiguration in color and look that makes me think of making the move. A slip on has been something Ive always done with my rides going back to a Honda CB with a Kerker. Is there a step by step for idiots to install a slip on for the Capo that does all?
  1. Changing exhaust, spark plugs, race ecu and air filter on rsv4 aprc
    By Felipec in forum 2010-2018 RSV4 - All Variants
    Last Post: 12-04-2016, 06:27 AM
  2. Can you change exhaust port timing by just lifting the barrel??
    By RSV4ME in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 10-15-2014, 02:11 AM
  3. Oil change Exhaust tube
    By Larry Myers in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 04-25-2009, 10:41 AM
  4. Need to change exhaust
    By snoggin in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 05-04-2004, 05:29 PM
  5. changing exhaust mufflers???
    By a5hl3y2k3 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 02-06-2004, 08:32 AM
