Results 1 to 15 of 27
Thread: best battery for rsv mille r and how many cold cranking amps do you need?
    Apr 2017
    NC
    As on my triumph a weak battery kills the sprag is this the same on the this bike?
    and best battery doesn't have to be the most expensive
    apriliaforum Junkie Barry Sheen's Avatar
    Dec 2012
    My own private Idaho.
    Start here....... http://products.batterytender.com/Ba...t-Battery.html
    Btw...keep her on a trickle charger too.
    "slow is smooth and smooth is fast"
    Apr 2017
    NC
    Yep have all my moto's on them, like the noco's smart chargers better
    Have you read good things about their batteries? Heard that there was a lot of conglomeration in the battery business, mainly china!
    Like Odessy batteries
    Dec 2012
    Quote Originally Posted by pescarr View Post
    Let me just say I haven't heard any bad things about them. Batteries can be a bit of crap shoot...period.
    Apr 2017
    NC
    this battery is $78.00 at afi racing has 180 CCA
    http://www.af1racing.com/store/Scrip...Yuasa+YTX-12BS
    this one at battery stuff.com is $41 also is 180 is this one crap
    https://www.batterystuff.com/powersp...sYTX12-BS.html
    May 2012
    Melbourne, Australia
    I'm using a Shorai . Had it in there only a couple months though. They claim 270 CCA. Certainly turns over my Mille without any problems!
    apriliaforum Junkie CHAPlain's Avatar
    Jun 2013
    sw USA
    Ive been running the Shori for over a year now. It does not like to start in the cold. I dont mean cold cold i mean cool cold. Otherwise no problems.
    Sent from my SAMSUNG-SM-T217A using Tapatalk
    apriliaforum expert J.R. Bob Dobbs's Avatar
    Aug 2008
    McGaheysville, Va
    I've had the Battery Tender brand lithiums in all my bikes the last four years.
    Jap bikes suck.
    apriliaforum expert ScottG's Avatar
    Apr 2013
    wpbfl
    Same here, have the Battery Tender 240 cca version in 3 bikes now. When I put the first one in my zx14 my friends all thought I was nuts until it fired up that big 4 instantly. The only one I have to put on a battery tender is the ape, fucker seems to eat electricity.
    Aug 2008
    McGaheysville, Va
    Yes, about every two weeks I put it on the tender to top it off, takes 12min. If I fail to remember, it takes over an hour to top off, so the bike sucks juice just sitting.
    I don't leave on tender all the time, I want the first start on a ride to be proof that the battery is functioning properly, and I'd rather have it quit in my garage rather than out on the road. Learned this the hard way. Also I had one fail in "full charge all the time" mode.
    Jap bikes suck.
    Apr 2017
    NC
    all good info, thank you
    Jul 2009
    Earthx 24c lithium iron phosphate battery has been on the Falco for 2 1/2 years. Starts on the button and not a single no start, tested as low of 5 degrees celcius. Doesn't need to be hooked up to a battery charger or anything. Have an upgraded strater system with 100amp yam relay, motoelectric cables and mosfet rectifier hooked up directly to the battery. Battery weighs about 1100 grams, almost 3.5 kg lighter than AGM battery.
    Jul 2014
    Ireland
    I use a yuasa with no complaints.
    imho the wiring mod is essential on these bikes. I used to rely on always using the trickle charger and I still went through 2 batteries in 2 years.
    With the wiring mod done, my bike starts on the button. When I do put it on the charger, it's always topped up after 2 minutes...used to take a lot longer.
    I don't miss that horrific spag sound either.
    apriliaforum Junkie dasrider's Avatar
    Feb 2013
    Central NC
    I came from a 2005 Triumph Speed Triple that went through 1 stator, 2 R/R's and at least 3 batteries that I know of in its 4-owner history so I totally get the bad battery tendencies in some bikes. My ape lives outdoors and I only charge it occasionally. I've found that any new battery combined with a higher spec 150A Yamaha starter makes the bike start much more enthusiastically. I'd like to spring for a nicer Li-Ion battery for the weight savings, but for now I've got a standard lead acid battery in there with no issues.
    Apr 2017
    NC
    Bought the battery tender lithium Iron battery recommended by barry sheen and other's at Summit racing for $109 and free shipping wondering if the battery tender Jr will work on that battery or do you need a smart charger?
  1. Best battery for 09 RSV?
    By TeddyG in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-17-2014, 08:41 PM
  2. Best Battery for 2003 Tuono RSV 1000?
    By MikeSchinkel in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 11-02-2006, 12:45 PM
  3. The best slip-ons for RSV mille need help
    By NellyMiha05 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 11-16-2004, 09:04 PM
  4. Derestriction question for RSV Mille
    By Kart57 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-11-2004, 01:07 PM
  5. Best Chip For 2002 Mille?
    By NAwlinsRSV in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-19-2003, 11:07 AM
