Results 1 to 13 of 13
Thread: Greasing rear swing arm and dog bone
    apriliaforum Member captbarb's Avatar
    Jun 2012
    norfolk england
    Thinking of giving this a go on my bikes has anybody got any advice on carrying out this task and any advice on pitfalls i might come across tools I have is trolly jacks times four.front and rear paddock stands to carry out this task.
    Rsvr 2000
    Rsvr 2002
    Tuono Factory 2005
    It is a simple matter of disassembling, cleaning, inspecting, and reassembly. I suppose the biggest pitfall would be having the bike fall on you so be safe. People often lose needles. It helps to spread a clean white drop cloth under the bike to catch everything. Some do this job with the rear wheel in place but it is so much easier with it out of the way.
    Jun 2012
    norfolk england
    I think the rear wheel will be out for this job I suppose the swing arm can just be supported to take out needle bearings either side of swing arm. And then disassembly of dog bone of the bike carefully to catch if needed the needles in there I assume just any good waterproof grease will be okay or does it need to be high temperature water proof grease being so close to hot pipes and engine.
    Rsvr 2000
    Rsvr 2002
    Tuono Factory 2005
    I don't know if you can get it over there but I use Bel Ray waterproof grease for all those bearings.
    Jun 2012
    norfolk england
    Okay KZ will see what I can find cheers
    Rsvr 2000
    Rsvr 2002
    Tuono Factory 2005
    Dec 2012
    Paimio, Finland
    Mille Aarrr -02 & KTM 625 SXC -05
    Jun 2016
    North Yorkshire, England.
    I've just done this job. You need to ensure you're up to speed before you start, and do some research.
    For instance, the swing arm has captive needle rollers on the left side and a double roller bearing on the right.
    The axle has a 14mm allen head and a lock nut requiring a specialist castellated socket on the right and a 26mm lock nut on the left; these all need torquing
    down to the correct settings on rebuild.
    You'll need to remove the exhaust and rear shock to gain access and either the chain will need splitting or you'll need to remove the chain complete with
    front sprocket to remove the swing arm totally from the bike.
    I also used an Abba stand with swing arm removal adaptors; I think anything less will make the bike unstable while working on it, especially retorquing
    the axle lock nut which is about 90NM.
    Just a few of my observations when I did this job 2 weeks ago.
    Jun 2012
    norfolk england
    Wow it looks a mammoth job looking at that thought I would be able to leave shock in place at top and just take the part of exhaust in the way
    Rsvr 2000
    Rsvr 2002
    Tuono Factory 2005
    Jun 2016
    You can't remove the rear header without loosening the front one to allow the collector to drop out of the way.
    x10 easier to remove the shock to get to the rear header bolts and you need it out of there if you're dropping the swinger.
    It's actually a real easy job, you've just got to remove some other bits to get access and have the right tools ready!
    Mar 2017
    Morocco
    It is easier than it appears to.
    Necessary too.
    Here is a link:
    https://youtu.be/DVNuDsSTa_U
    apriliaforum Junkie dfoustou's Avatar
    Aug 2014
    silver spring
    Nice thread with great pictures and tips!
    Dionysis
    79 CX500C
    07 RSV1000R
    08 WR250R
    IBA#58777
    Dec 2012
    Paimio, Finland
    If you have aftermarket fixed rearsets you can lift the bike from them with something like this:
    That is what I did just two months ago when regreasing the linkage. I did not push the bearings out but cleaned and greased the dog bone bearings on the table and the swing arm needle bearings inside the swing arm.
    I have also used those lifting the front up below the engine to disassemble the head bearing for instance.
    Jun 2012
    norfolk england
    Well all done borrowed mates ABBA stand used the belray. Water proof grease it can be done with exhaust on or not done two bikes also filled the cavity between the two needle bearings with grease .
    Rsvr 2000
    Rsvr 2002
    Tuono Factory 2005
  1. Is it supposed to be like that (rear suspension linkage and dog-bone question)?
    By spacek in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 06-25-2014, 05:16 PM
  2. Anyone got a spare swing arm and wheel?
    By johan327 in forum RST1000 Futura (all years)
    Last Post: 09-13-2005, 05:46 PM
  3. question about the rear swing arm
    By Tom1o56 in forum RS125 Euro-archive
    Last Post: 08-31-2004, 02:16 PM
  4. ! side swing arm and GP pipes?
    By Dveloped in forum RS250
    Last Post: 02-02-2004, 06:39 AM
  5. 98 Swing arm and wheels on a 95
    By flynn21atwork in forum RS250
    Last Post: 05-05-2003, 07:44 PM
