Results 1 to 10 of 10
Thread: Rsv4 rf auto rev fault video
    Nov 2017
    England uk
    Hey guys . I'm in need of a little help here .
    not had my rsv4 rf long and it's having a few issues .
    It cuts out in 2nd gear as if the kill switch has been hit then after pulling over the revs chase like In this video . After re setting the ignition it returns to normal.
    This has happened multiple times. Any help would be realy appreciated as it's been back to the official dealer a few times and after replacing the front throttle bodies the problem remains
    thanks . Mike
    https://youtu.be/ZUd_rzi1nuo
    37 miles E. of ATX, TX USA.
    Think you will have better luck finding an answer in the V4 section instead of the V-Twin section. I moved your thread.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Nov 2017
    England uk
    Thanks ��
    Jul 2012
    england
    You need to get the fault codes read to see what the issue is. The revving up and down is a limp mode and could be caused by many things. Take is back to the dealer and let them plug into their PADS or you can plug in yourself with guzzidiag software.
    Nov 2017
    England uk
    The dealer have had the bike back a few times now . The fault code indicated the front throttle bodies so they got replaced but the problem persists.
    Jun 2017
    Korea south . Seoul
    Most of these symptoms are seen in poor MAP sensors
    But it may be something else, so we need to check the error code.
    Jul 2012
    england
    You could try and swap the map sensors around and see if the fault moves. I.e put the front MAP sensor onto the rear set of throttle bodies and see if the fault code moves to the rear tb’s.
    If you have lost confidence in your dealer then take it to somebody else that has a good reputation with v4’s.
    aprilia performance https://www.apriliaperformance.co.uk/
    john coughlan http://www.apriliabikes.co.uk/
    Nov 2017
    England uk
    Going to see it out with this dealer for now . I bought the bike from them in may this year and although it's out of the two year warrenty they are so far doing this work for free. I would have liked to extend the warrenty but it's unavailable on the rf model for some reason .
    Mar 2015
    Florida
    Quote Originally Posted by Fish80 View Post
    Is there a factory extended warranty with Aprilia now or are you talking of an aftermarket extended warranty?
    Nov 2017
    England uk
    Yes there usually is a factory extended warrenty but unfortunately it is not available on the rf model for some unknown reason
  1. Video of the 2017 RSV4 RF on track
    By Shaman666 in forum 2010-2018 RSV4 - All Variants
    Last Post: 03-19-2017, 11:24 AM
  2. [RSV4] 2016 rsv4 RF
    By Legalledbetter in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 04-21-2016, 05:22 PM
  3. [RSV4] M50/M430 calipers and matching m/c off 2016 RSV4-RF, Calif
    By amauri in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-12-2015, 12:28 PM
  4. [RSV4] complete body panels set off 2015/16 RSV4-RF (calif)
    Last Post: 10-08-2015, 12:06 PM
  5. [RSV4] 2016 Rsv4 Rf for sale Oklahoma
    Last Post: 08-02-2015, 07:52 PM
