Results 1 to 15 of 16
Thread: Single spark 1400 motor is now running...
    Took longer than expected and was a fair bit more complicated than we thought it might be. Should be ready for mapping next week if all goes according to plan. It's in Mark's Griso so it's all set up for logging purposes. Let the fun commence!
    Pete
    Professional Goat Burster.
    Aug 2009
    Perth Western Australia
    Awesome Pete.
    As they say in drag racing "Ya can't beat cubes".
    Got any pics ?
    Dec 2015
    Sydney
    What makes it "single spark?"
    As in, not multi spark?
    Cali motor runs twin plugs Chris. The 1200's only run one.
    Dec 2015
    Sydney
    My standard 1200 heads have twin plugs.
    I thought you had a Bellagio?
    Dec 2015
    Sydney
    I do, and when I bought it, it was advertised as having 1200 heads and barrels with an 850 crank.
    If it doesn't then I want my money back!
    Back on topic, why delete one plug per head?
    They didn't, one was added for the 1400.
    37 miles E. of ATX, TX USA.
    Twin plugs in a 4 valve head with one located centrally are completely non beneficial for anything other than cleaning up a tiny fraction of emissions bs. Think about it, 4 valve head, plug located in center...flame front effectively reaches extent of travel in same amount of time no matter since the second plug located next to the cylinder wall. Keep us posted...maybe with some pics too? So this is a 1400cc Griso conversion, sounds very cool!
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Yup, I'm not going to give too much away because there has been a history of my generosity being exploited by assholes but I'll copy you in on a run down of the details I'm preparing for some mates. Just let it be said its a long way from being a simple drop in big pistons job.
    Pete
    Cool. I have no intention of copying your work Pete, it is just a fascinating project to me. I get it though, I have seen pics and posts using wither my words or photos distributed all over the net to make other people money or give them credibility.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Dec 2015
    Sydney
    Ok, I see what you are getting at now Pete.
    I was under the initial impression that the Cali had multi-spark technology (firing the same plug multiple times during that stroke).
    Anyway, having a central plug and an offset plug in the same head can be of benefit if the intake charge is directed towards the average centre between those plugs and not the geometric centre of the head volume. In other words the intake charge is deliberately directed towards the outside of the head by virtue of the curved manifold creating a horizontal swirl.
    That old chestnut!
    Nah. With a 2V Hemi head combustion chamber there are benefits as, especially in high compression engines the poor old flame front has to traverse an alp of alloy which takes an age so having flame propagation on two fronts can be handy. With a modern combustion chamber with four valves and a compact pent roof combustion chamber with a narrow included valve angle an extra plug will do very little.
    I was told by a Piaggio suit that the reason they stuck an extra plug in the Cali 14 was to combat 'Surging' at idle and low RPM. I now think that this was simply the usual Piaggio suit mouth-flap as the single spark 1400 betrays no such conditions. While there may be a very minor benefit as Micah mentions to combatting end gas issues and maybe reducing oxides of nitrogen I actually think that the main reason they twin plugged it, (The second plug only fires at lower rpm.) was to make the wretched engine shake at idle so it would bounce around in its rubber mounts 'Like a Harley'! Which is pretty damn sad but it would fit right in with Piaggio 'Groupthink'.
    As it is the main challenges to the Guzzi design, in both 1200 and 1400 forms is not the number or location of the plugs but the fact that it combines that very nice, modern, combustion chamber with a side draft intake and exhaust set up. Combine this with the weirdly long duration and overlap and you end up with a motor that is to be honest, pretty lousy in terms of volumetric efficiency and why if tuning via specified AFR's conventional wisdom has to be thrown out the window due to charge transition issues! If you want an 8V Guzzi to run like a sack of shit and drink fuel all you need to do is stick a short, open pipe on it and rev the tits off it.
    pete
    Well, it went home today. Map development will now commence but we went out for a 100km flog yesterday and nothing leaked, fell off or blew up! Then we adjourned to the Royal for a celebratory ale!
    The 1400 with my 'Tree Frog' behind it and Michael's blackie in the background.
    First impressions running a barely modified 1200 Hi-Pipe map are favourable!
    Pete
    WV... Northern Panhandle
    Awesome! Makes one think of the possibilities... Breva 1400?
    02 aprilia Futura
    15 aprilia Caponord 1200
  1. dipstick blow by when the motor is running
    By RedMani in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 07-07-2013, 12:05 PM
  2. Tuneboy is now up and running. Some questions on basic settings.
    By ELMOSISU in forum ETV1000 CapoNord (2001-2007)
    Last Post: 10-29-2010, 10:02 AM
  3. KX125 Motor for rs project IS NOW 4 SALE
    By 911jimmy in forum RS50 Technical
    Last Post: 06-30-2003, 04:41 PM
  4. Front turn signals now running lights
    By mtrionfo in forum ETV1000 CapoNord (2001-2007)
    Last Post: 10-24-2002, 10:09 AM
  5. What's the spark plug gap is??
    By Jeremy Rawcliffe in forum Pegaso 650 Cube and IE
    Last Post: 07-15-2002, 02:28 PM
