Results 1 to 7 of 7
Thread: Rear wheel ABS sensor
    Southampton
    Does anyone know of any alternatives? Or has one sitting on a shelf looking for a home? I noticed on my ride yesterday that the rubber housing has split, exposing the wiring. I'm sure I can patch it but, long-term, I imagine it's better to replace. I suspect I'm looking at approx 85-90 although I see AF1 sell it for 55 + shipping.
    Scottsdale, AZ
    Quote Originally Posted by goldencapo View Post
    Before it gets any worse, get yourself a can of liquid electrical tape spray. http://tinyurl.com/y9mguun5
    Remove the sensor from the bike and clean it spotless. Then give it a shot of the spray into the split, and let it dry. Follow with several thin coats of the stuff on the entire housing, letting it dry thoroughly between coats. That should be the last of the problem.
    apriliaforum Member shi_bumi's Avatar
    Oct 2012
    Turkey
    BMW F650 sensor is the same. I am not sure about the plug side. Maybe you have to modify the wiring. There are tens of ABS sensor on Ebay listings.
    https://rover.ebay.com/rover/0/0/0?m...2F332234620093
    "I'm not sure whether I'm an actor who races or a racer who acts." Steve McQueen
    Southampton
    Thanks both. I'll inspect the split more closely this evening.
    Southampton
    Bollox, it's not the ABS sensor, it's the speedo sensor - 100! Liquid electrical tape ordered.
    Jun 2009
    oldham uk and soon gibraltar
    Your ok for speedo sensor all the aprilia with the 1000 rotax motor fit ( apart from the futura ) so eBay is your friend capo/ tuono,Falco,Millie . Plus 1gt101dc Honeywell s&c sensor Hall effect gear tooth 41.86 item no 132009941053 is the right one according to someone on hear but you will have to fit your plug on the end
    Southampton
    Thanks for info Geoff
  1. WTB: rsv4 rear wheel abs sensor
    By Pedrosi in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 09-15-2017, 09:50 AM
  2. Rear wheel speed sensor
    By davidon in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 06-02-2017, 11:46 AM
  3. Rear Wheel Speed Sensor plug location
    By Jinxx in forum 2010-2018 RSV4 - All Variants
    Last Post: 12-29-2015, 07:35 PM
  4. speed sensor rear wheel
    By waspometer in forum ETV1000 CapoNord (2001-2007)
    Last Post: 03-29-2012, 02:09 AM
  5. WTB: Rear Wheel Speedo Sensor
    By ejh in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-30-2011, 09:32 AM
