Results 1 to 6 of 6
Thread: Thread insert for chain adjuster bolt?
    Nov 2017
    Pooler, ga
    So I'm done googling my threaded insert is wanting to fall out any ideas on how to fix it?
    Feb 2009
    First post...straight in with a question.
    An intro would have been nice....but never mind...next time maybe?
    What exactly do you mean by a 'threaded insert'?
    Is it the bolt that's wanting to 'fall out'?
    Assuming that's the case, it would maybe appear your s/a chain adusting thread is stripped and fucked, probably be repaired ok with a helicoil or similar.
    Jul 2017
    Bay Area, California
    If the threads themselves are coming out, you'll want to drill and use a helicoil to bring it back to the correct size of the OEM bolt.
    I had to do that on my superduke.
    Nov 2017
    Pooler, ga
    Quote Originally Posted by Tifa View Post
    I apologize for the no intro...a previous owner put a random bolt in it and I ordered a replacement. However the replacement is a bigger diameter. Either way I was messing around with the assembly and tightened the adjuster all the way in and it forced the aluminum insert out. I have never seen something like that before.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    There is no insert as delivered from aprilia. If there is truly an insert coming out I suggest someone installed it after it was delivered. Post a picture if you can.
    Sep 2015
    Phoenix
    Agreed. Possibly a helicoil?
  1. Chain adjuster Bolt
    By tuono07 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 04-24-2016, 08:04 PM
  2. 2007 Factory snapped chain adjuster bolt - HELP!!
    By Lumpy_bd in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 11-18-2015, 03:39 AM
  3. Chain adjusting bolt
    By MickyC51 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-16-2011, 05:19 PM
  4. Chain adjuster bolt
    By seadog in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 06-06-2011, 12:27 PM
  5. Gilles chain adjusters for Tuono
    By Soggy in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-17-2006, 07:09 PM
