Results 1 to 12 of 12
Thread: capanord 12v power outlet fuse
    apriliaforum newb obaz's Avatar
    Oct 2017
    Ukraine
    Hello there !
    Recently I`ve noticed that 12v power outlet of the left side of my capanord isn`t working. I`ve checked all the fuses (one the dashboard and near the seat) - and all of them are ok. is there a any fuses location I`ve missed.
    thank you in advance
    here is explanation of power outlet location on capanord. picture is not mine
    pegaso cube 1998 -> etv 1000 2006
    May 2016
    Costa Rica
    It is the "E" fuse up front on the dash. Far right fuse. Name:  fuses.png
    apriliaforum Member Obi-Wan Kenobi's Avatar
    Oct 2013
    Leicester, England
    Mine packed up ages ago because the wiring at the back corroded as it get lots of wet and crap thrown at it and its a cheap part.
    I disconnected the wiring, extended it and connected it to a bar mounted 12v socket with additional usb charging point.
    These are not the Droids you're looking for....
    N. Cal
    Quote Originally Posted by Obi-Wan Kenobi View Post
    A+
    I as well put one up on the dash. I don’t use the original one - stupid location really. If you really want one there it won’t be hard to modify an aftermarket one to fit, however best to remove wiring if it has given up and reroute a nice one up north!
    06' Caponord
    Jun 2009
    oldham uk and soon gibraltar
    I've one up top but still use original one for my optimate charger as they do a lead that fits the 12v plug
    apriliaforum expert brmbrm's Avatar
    Mar 2004
    North Wales
    I also use the standard accessory outlet to check battery voltage, as long as you know the wire connections are clean.
    Using a combined digital voltmeter/ accessory connector.
    Checks the battery voltage with the headlights off
    My name is Dave,
    bike's name is Black Betty.
    When you're traveling, you are what you are right there and then.
    Caponord - Douglas Dragonfly - 1942 Harley back again
    Pegaso - Matchless G3LS - BSA A7SS - 1942 Harley - Matchless G80/600cc - Matchless G3LS - BSA C15 - Velocette
    apriliaforum expert Prankster's Avatar
    Jan 2006
    Ponca City, Oklahoma, USA
    I saw this one on ebay, and I liked it. $11.05
    https://www.ebay.com/itm/12V-to-5V-W...gAAOSw-itXrBZn
    Loki J. Prankster
    In my life, it's not the choices I make, it's the chances I take that influence my life the most.
    May 2016
    I have made second power outlet on the dashboard with Aukey USB charger which is the only one that actually is charging my LG G2 with GPS on, 100% screen brightness and BT on. I had a few cheap USB chargers like this one above and none of them worked as it should. Couldn't get enough juice to charge my phone.
    https://photos.app.goo.gl/wEW6mKZK4DgI0uqF2
    Jan 2006
    On your advice I bought this one.
    https://www.ebay.com/itm/US-UPS-ship...19.m1438.l2649
    Quote Originally Posted by skvrnsk View Post
    Loki J. Prankster
    May 2016
    I have CC-T1 model with QuickCharge support, which I think is the key to maintaining enough charging power. Of course, You need to have a phone with QC support too and an Aukey USB cable, which makes a big difference. I have tested it with six or seven different cables and there is a significant difference in amperage. Even some of the good branded cables couldn't deliver enough power. I don't recommend cheap Chinese cables from Ali/eBay. They couldn't deliver more than 500mA and none of them, which I had a few, worked as standard USB cable to connect anything to PC. I assume they're made only for charging, but of course, You won't get that information from Ali seller site.
    But I'm no expert and all I know is that configuration works for me... for now. I'm thinking about making a permanent power supply straight from under the dashboard with one or two USB plugs, so it could be used in heavy rain without hesitation. Already had to clean it all from some rust and patina coating.
    Jan 2006
    I looked but I could not find anything better than a Aukey 3.0 USB Type-C cable.
    There are braided Type-C cables; I just wonder if they have the same output.
    However, I did find this:
    AUKEY-36W-Car-Charger-USB-Quick-Charge-3-0-Car-Charger-Universal-Fast-Charging
    https://www.ebay.com/itm/AUKEY-36W-C....c100033.m2042
    Loki J. Prankster
    May 2016
    I had mine included. I think it comes with each of their chargers.
  1. Is power outlet fused?
    By patrilia in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 07-26-2013, 04:29 AM
  2. 12V Switched and Fused Power
    By Wallaman in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-20-2011, 01:55 PM
  3. power outlet
    By rst4me100 in forum ETV1000 CapoNord (2001-2007)
    Last Post: 03-21-2007, 07:15 PM
  4. Power outlet
    By quicktoys2 in forum ETV1000 CapoNord (2001-2007)
    Last Post: 03-03-2007, 01:41 PM
  5. euro (BMW) style power outlet??
    By USA MEDIC in forum ETV1000 CapoNord (2001-2007)
    Last Post: 10-30-2004, 09:31 AM
