Results 1 to 10 of 10
Thread: Rally 50 AC better performance
    Nov 2015
    Portugal
    Post Rally 50 AC better performance
    Hi, I have a rally 50, bike was sitting for some years because when I was a kid the bike was always letting me down for some reason. But "recently" I decided to make it my daily.. First, what do you think of this scooter?
    I've "rebuild it", new piston, rings, gaskets, air filter, spark plug, reeds, 5g rollers, kevlar belt, etc? Everything else its stock
    I'm, loving the bike but Im actually trying to increase a little the top speed. It is 75km/h on straight road, its ok? What can I do, not expensive, to get more top speed? I feel like 1/4 and 2/4 throttle is very nice, but 3/4 and woot feels "buggy"
    Tryed to put the needle a notch down, didnt feel any difference
    Do I need a better exauhst? Bigger carb? Just looking a little increase
    Thanks for the help in advance
    ontario
    what year is it and wich engine?
    what type of daily drives and what speed roads are we talking about?
    its normal not to pass 75kmh with less than 7g weights on a piaggio engine. with that said... it needs a 70cc kit and a torque pipe to increase road speeds and gain performance.
    let me know what carb you have and i will continue....
    Nov 2015
    Portugal
    Hi, thanks for the reply.. Year its 97 and the carb its a phbn12
    I drive it 20km every day, 10 go to work, 10 back from work.. And I go very early, like 5am and are very straight roads.
    many thanks
    ontario
    thats a nice ride! the size and shape of those is picture perfect.
    ok so you need a carb and a malossi 70cc cylinder and the malossi exhaust.
    you need the carb replaced first or the engine will get damaged.... winter is a good time to do it.
    i like the dellorto sha carbs for torque pipes. i suggest the dakar sha 15mm carb with the 11 slide and a tunr airfilter. you will want the polini suicide choke and the malossi carb adaptor also. then just bolt it up and drive away... treatland.com has all that stuff
    ontario
    Quote Originally Posted by rafaapm View Post
    I'm, loving the bike but Im actually trying to increase a little the top speed. It is 75km/h on straight road, its ok? What can I do, not expensive, to get more top speed? .........
    the kevlar belts are very stiff / it is killing performance. try the stock belt or something and 6 gram rollers. mix the 7g with the 5g to reach 6grams if you have to but watch out for big flat spots on the rollers.
    let me msg my friend JIXAW. he has that carb setup and many other mods on that engine.
    Nov 2015
    Portugal
    Thanks! Im not looking for changing the piston because its brand new, maybe some months now, but Im gonna be looking for it
    Im gonna look to change my rollers and exauhst first, now I have something to start
    Can you get me the better carb settings? Im out 1 and 1/2 turn in the air screw and needle is in 2nd notch from top
    ontario
    -get the malossi stuff. the cylinder and pipe....
    no carb settings will be right if you run the rollers to light. get a rpm gauge/ tachometer and try to keep it at peak power wich is about 7500rpm. then ask me again.
    Nov 2015
    Portugal
    Ok, the cylinder and malossi stuff will do maybe next month...
    With get the tachometer and in between change my rollers to 6,5/7g..
    One question, do you know hebo racing exauhst? I can get one very cheap, dont even know if works on my scooter
    ontario
    yes i had a hebo performer i think it was called. it was kinda ok for ten years ago. the malossi makes a similiar zingy sound but has way way a longer powerband and the same hp. mine was red and it matched my bike. everybody even 5 years ago was on the poor mans midrace kick then. now finally a couple sport pipes available that make the hebo not look great by any standards.
    the malossi pipe is called the art of performance and it needs a 15mm-17mm carb on the 8hp sport cylinder from malossi. if you want a nice cylinder still in sport class to go with that pipe the trophy 70cc cylinder and a 16-19mm carb will give you ten hp. those are the best two choices and the pipe works great on both.
    ontario
    it is a racey type pipe and you dont come close to enough kit to power it. it needs a 5000rpm clutch and much more.
  1. 1996 Aprilia Rally 50 Ac - Service and Tunin
    By RuiG in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 09-10-2012, 11:30 PM
  2. Rally 50 ac
    By haza in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-14-2011, 03:36 PM
  3. Rally 50 AC - identifying switched live
    By drain_sniffer in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-19-2011, 05:19 AM
  4. Where to buy: Top Speed Kevlar belt, Rally 50 AC?
    By Nedry in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 09-25-2010, 03:27 PM
  5. Leaking Rally 50 AC
    By xdbx in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-11-2007, 06:30 PM
