Results 1 to 15 of 25
Thread: Double exhaust for Mille ME
    Oct 2017
    Antwerp
    Hi.
    I am looking to change the standard muffler on my Mille to liberate all that beautifull music from the engine. For that I was looking for the double exhaust from the R, but is very difficult to find.
    Recently I found an double exhaust (intake manifold and the two mufflers) from a 1000R. Will this fit on a Mille? The engine is the same, yes? But what about mountingbolts, faring, swingarm, etc ... ? Will it fit?
    Anybody tried to fit an exhaust from a 1000R to an Mille? experiences?
    May 2007
    Durham U.K.
    you need to talk gen1 and gen2.
    gen1 bikes have a 3 stud bolt pattern on the exhaust port.
    gen 2 have a 4 bolt pattern.
    if its a gen 2 system its a lot of work cutting and welding to make it fit a gen1.
    Nov 2017
    Brocks UK
    How about the other way around, going from the twin zorst to a single on a gen 2?
    That would require at least the same amount of work; cutting and welding to change the flanges. And even then it might not be so simple.
    Nov 2017
    Brocks UK
    Looks like more cash going out on twin aftermarket cans then. I did think it would be only a matter or changing/modifying the original system to take a collector (box 2 to 1) under the bike then buying one can and link pipe. I haven't had the chance to go over the machine as yet so your input is valued, thanks kzmille.
    I've seen this talked about a few times on the gen 2 forums but I don't know that anyone has done it. There is no doubt it can be done but till someone goes through the process there is no telling how much trouble it is.
    May 2007
    Durham U.K.
    the gen2 and gen1 rear headers take a slightly different route past the shock and thru the swinger. A gen2 header on a gen1 bike fouls the shock and needs cutting and welding. Or change to gen2 swinger and shock and dogbones etc.
    Also the headers and collectors are not mix and match compatible.
    Theres no easy route, it aint no plug n play.
    Oct 2017
    Antwerp
    OK, thanks guys.
    Guess I'll keep looking or just go for an aftermarket single exhaust.
    Dec 2012
    Paimio, Finland
    and the collector mod!
    Mille Aarrr -02 & KTM 625 SXC -05
    NE, PA
    Quote Originally Posted by Luc View Post
    OK, thanks guys.
    Even if you find a Gen 1 dual exhaust you would still need to change the shock and suspension links on your ME as a group for the shock, spring, dogbone, and triangles that came on an RP.
    The dual Gen 1 exhaust will not clear the the shock linkage on the 98-00 ME bikes.
    The RP bikes use much softer springs and a significantly different link ratio & shock valving, so you do not want to mix and match shocks, springs and links from ME and RP bikes.
    As JMH said going with a collector mod on a single exhaust system is a very good option.
    1985 Honda VF500F Interceptor Red
    1985 Honda VF500F Interceptor Blue
    1992 BMW K1100RS ABS
    1993 Honda CBR600 F2
    1995 Ducati 916 Monoposto
    1999 Aprilia RSV Mille
    Oct 2017
    Antwerp
    Quote Originally Posted by DanV990 View Post
    What is the collector mod?
    What does it do?
    May 2007
    Durham U.K.
    when your at the top of a page, look over to the right hand side, there is a button marked search forum. hit it and type "collector mod", all the info you require will be there
    Oct 2009
    What does it do?
    Google Redratbike modded collector some dyno charts should appear
    How about a nice 10bhp in the midrange taking out the flat spot and a few bhp at the top mimics the flow of a dual system
    The dyno charts were plug and play on a bike running open airbox and old dr Rossi chip and akrapovic race can ...a bit more power can be had by having the tb's set up to suit or custom map if running a pc3
    I would suggest an aftermarket eprom to adjust fuelling
    Oct 2017
    Antwerp
    Quote Originally Posted by redratbike View Post
    So do you still make these modded collectors?
    I already found a PCIII. My plan is to get Mille back into running state (having some clutch problems) during the winter, doing some test-drives/getting acquainted in the spring and getting here tuned in the summer. There is no need for extra power (120 hp is enough for me) but it sure would be nice to get rid of that homologation dip around 4000 rpm
    Oct 2009
    Yes I have one here ready to go and are available anytime
  1. [Mille] Arrow 2-2 bulldog exhaust for early mille tuono or modified falco
    By Twins in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 11-03-2015, 09:47 AM
  2. High Mount Arrow Full Ti Exhaust for Mille, Falco, Tuono - CC, TX
    By AJJohnson in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 07-19-2013, 08:30 AM
  3. undertail exhaust for mille-r, what options?
    By zilog in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-01-2012, 03:38 PM
  4. Front Wheel and Shotgun double exhaust for 2005 Tuono
    By erliban in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 12-12-2011, 10:58 PM
  5. Got 200 saved who can do me the cheapest exhaust for the rs125?
    By ApriliMo in forum RS125 Euro-archive
    Last Post: 09-30-2003, 09:17 AM
