Mods: Modified Öhlins fork from mille R, EBC brake discs, HEL front brakelines, Carbon RS 250 front fender, Wiring mod for charging. Engine related:05 map, Iridium plugs, tuneboy, derestriced intake, old mille airboot, staintunes exhaust. Lambda bung hardbrazed in the "breadbox". Öhlins mille R rear shock with 110N/mm spring and the integrated hydraulic preload adjuster. LED Voltmeter installed inside the dash for monitoring charging. Duc 999 radial m/c for brake and clutch. EBC 320mm brake discs
CBR 600 -07 MOSFET R&R FH008EE providing stable 14.4 - 14.5 V (with my wiring mod). Daytona heated grips with mccoi pwm controller and automatic chain oiler
